Home > In Car Electronics (L322) > Can't Locate a Medium Speed Can Bus Fault - 2010 L322
Stuart-
Interesting pointers, thanks. And I'd forgotten about High Peak. I'll give him a call tomorrow. Edit: It seems High peak 4x4 has closed down according to Google. But the search threw up Hallam Bros who I will ask.
Both fobs have had batteries. The clockspring and steering angle sensor I've not heard about in my research, nor the rear fibre optic cables. I shall ask about those.
WEBAC puts this car at over £8k if you input the reg. I'd rather fix it if I could though. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
Post #646648 27th Oct 2022 6:50pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Quote:
£108 later I had a proper spec Varta battery.
This is a long shot as what you have, being new, should be ok. However, for £108 I doubt this an AGM battery which it should be for this vehicle. Everything seems to be pointing towards low voltage, are you absolutely certain that new battery isn't faulty (it happens)? Is the alternator ok (you may already have looked at this, I haven't read every post in depth). Just some ideas. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #646676 28th Oct 2022 7:48am
biggles3124
England 2008 Range Rover Vogue TDV8 Tonga Green
Just too throw my two pennoth into arena!
There is a device or something that cuts the electrics in the case of a collision ?
Couldnt possibly be connected (?) could it ?
Post #646709 28th Oct 2022 12:54pm
Stuart-
I collected it from the garage with a view to PXing or selling it this next week.
I'm wondering if during their work they might have got close.
It drove fine for a few miles, then on a roundabout where I'd expect the screens to go out, they didn't, but the car came up with the restricted performance light and went into limp mode instead. I limped home at 30mph.
Left it overnight and went to it this morning, no restricted warning light. I know it will come on again the next time there's a tight right-hand bend. And I know when plugged into the reader it will show many, many faults.
But the fact the screens stayed on makes me wonder if they were getting close. Or maybe just a red herring. 2017 4.4 SDV8 Autobiography in black
Post #646781 29th Oct 2022 12:27pm
GraemeS
Australia
If you had a tool capable of reading and clearing fault codes you would be able to clear the codes yourself then check again as soon as the fault occurred.
The restricted performance fault should be easier to find which might help find the cause of the other faults.
Does the speed of driving the tight right bend make any difference? Wondering if the faults are due to turning the steering or the body leaning? If jacking both front wheels off the ground then turning the steering causes the fault then that would help enourmously.
Post #646813 29th Oct 2022 8:45pm
Stuart-
I've had it in the indy as its done it but it throws up too many faults.
Yes, its a body-leaning thing rather than a steering thing. It has to be something in the dash moving as the car tilts. 2017 4.4 SDV8 Autobiography in black
Post #646872 30th Oct 2022 2:17pm
GraemeS
Australia
Maybe worth removing the footwell side panels to wriggle the wiring and connectors behind them. The panels are easy to remove.
Post #646896 30th Oct 2022 8:41pm
Stuart-
The indy spent three weeks poking around everywhere, they were at the point of removing the dash.
As it is, I'm buying a Vito van this week ( I needed it for work anyway) to plug the gap between this car going and finding a 17/18 L405.
I've taken an unseen deposit from a forum member for the car with a view to it going next weekend. I'm sure he will find the fault in five minutes and I'll be sick as a chip. Such is life. 2017 4.4 SDV8 Autobiography in black
Post #647087 1st Nov 2022 7:19pm
