![]() | Home > In Car Electronics (L322) > Can't Locate a Medium Speed Can Bus Fault - 2010 L322 |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 553 ![]() ![]() ![]() |
This is a long shot as what you have, being new, should be ok. However, for £108 I doubt this an AGM battery which it should be for this vehicle. Everything seems to be pointing towards low voltage, are you absolutely certain that new battery isn't faulty (it happens)? Is the alternator ok (you may already have looked at this, I haven't read every post in depth). Just some ideas. Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
biggles3124 Member Since: 03 Mar 2012 Location: Andover, Hants Posts: 103 ![]() ![]() ![]() |
Just too throw my two pennoth into arena!
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 407 ![]() ![]() |
I collected it from the garage with a view to PXing or selling it this next week.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
If you had a tool capable of reading and clearing fault codes you would be able to clear the codes yourself then check again as soon as the fault occurred.
I've had it in the indy as its done it but it throws up too many faults.
Maybe worth removing the footwell side panels to wriggle the wiring and connectors behind them. The panels are easy to remove. |
The indy spent three weeks poking around everywhere, they were at the point of removing the dash.
