![]() | Home > Technical (L322) > Intermittent heavy steering |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
Well everything was going well for a few days following fitting the new aux belt... then the belt tensioner failed |
| abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93
I know this is an old post, but did you ever get to the bottom of the problem?
| Friday 13th Member Since: 06 Nov 2022 Location: Kuala Lupur Posts: 2
Hey Pawl, and everyone first of all thank you for having me here..
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782
The wires to my MY12's servotronic valve recently broke which made the steering heavy. No faults were displayed but a fault code was stored for the valve. The valve is located in the section of the rack where the steering column attaches, mounted on the outside. You should see it directly above the gaitor on the driver's end of the rack.
Thank you for the tips! I will write again if the steering making problems again.. for now its smooth as a butter 🧈 I can turn the wheels with 1 finger! Haha hopefully it stays like this 🙏 |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
Friday 13th,
| All times are GMT |
