Home > Technical (L322) > Iphone to aux
Neil E
2019 Range Rover 2.0 PHEV Mariana Black
Iphone to aux
Hi all,
I`ve just purchased a lead that fits into the bottom of my phone which then has the connections for the aux between the seats in the rear.
http://www.amazon.co.uk/Phono-Cable-Apple-...amp;sr=1-3
Problem is I can`t get it to work! I`m wondering if I`m doing something wrong or I`ve bought the wrong lead.
I`ve connected phone, switched to aux on the touchscreen, put some music on the phone and nothing. Checked volume on both devices but still no sound.
Am I missing something??
Neil MY21 P400e AB
MY10 3.6 TD V8 Autobiography
55 Vogue se
Post #64758 19th May 2011 3:24pm
afaik the aux is for output only, not input..
Post #64762 19th May 2011 3:28pm
Neil E
christ! no wonder then!
So how can I get my iphone to play the music through stereo without having to buy a connection for the back of the head unit?
Or is this not possible? MY21 P400e AB
55 Vogue se
Post #64765 19th May 2011 3:31pm
not sure but there is loads on this subject here somewhere ..
Post #64768 19th May 2011 3:33pm
Neil E
thanks I`ll take a look through forum. MY21 P400e AB
55 Vogue se
Post #64770 19th May 2011 3:35pm
You can input via the aux I am pretty sure as I have done so with my Blackberry sounds files.... Confused
Post #64778 19th May 2011 4:14pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Shocked Shocked Shocked
Sorry scarey, I have to disagree - the 3.5mm aux "input" socket in the rear centre panel on D3,D4 RRS & FFRR is for audio input.
Looking at the link posted about the cable it appears to have two phono connections? How have you converted this to a single 3.5mm jack plug?
For the wife's D3 we bought this:
http://www.amazon.co.uk/Kensington-33429EU...B0011UK2HE
Works perfectly and charges the iPhone AND has a remote control Thumbs Up
I would check that your cable is the right one as it doesn't look compatible to me Rolling Eyes AND as a rule, never use the headphone socket on an iphone as the audio source - It has very low line output and therefore low volume through the cars audio system Wink
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #64781 19th May 2011 4:19pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
The 3.5mm RSE jack on my 2006 FFRR is for aux in and allows you to play music through the speakers. The red and white line-in inputs only allow you to play sound through the RSE.
Make sure your iPhone is turned up a the way, if that does not work, test the cable on something else and/or try another cable.
Gone - Range Rover Supercharged 2006
Post #64782 19th May 2011 4:20pm
Embarassed apologies all, i haven't got this feature so i wasn't sure...
Post #64784 19th May 2011 4:29pm
AMD
Also, set the iPhone sound setting to 'small speakers' it will inprove the quality. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #64785 19th May 2011 4:32pm
You can play video through the phono ports in the RSE panel, from your iPod for example. However it only plays on the REAR screens, not the front centre screen.
I bought the Belkin cable to do that. Discovery 4 HSE
Post #64806 19th May 2011 5:26pm
ZZT
United States
The real problem is that mp3 players are designed to drive headphones. Headphones don't need the same signal level as the AUX input. If you are going to use a headphone output, you'll most likely need some type of in-line amplifier. Google "portable headphone amp" or "Sound Shocker Pro" and you'll find lots of info. Almost all need some sort of power (battery or car plug-in) except Sound Shocker.
Post #65023 20th May 2011 1:33pm
JustinP
Sorry but I disagree.
The Aux-in is intended to be connected to a devices headphone socket, the issue us the aux-in Range Rover does not amplify the input enough. I agree that this shortcoming can be overcome using a headphone amplifier, but it should not be necessary.
The Aux-in in my old Mercedes was fine.
Post #65026 20th May 2011 1:42pm
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
I'll have a check on my lead, I bought it from ebay for £2.99 & can plug my iphone through the rear 3.5mm aux socket & it plays music without hassle.
Post #65034 20th May 2011 2:48pm
Ajay(UK)
I think we may be straying from the original post which was a concern specifically regarding an iPhone audio out and the correct cable - I was just pointing out that an iPhone has a very low output gain from the headphone socket and because of this the headphone socket is not really suitable to connect to the aux input in Land/Range Rovers! You have to use the main connector at the bottom of the phone which has a much higher audio output gain which works perfectly. Apple have obviously designed their phone that way "Health & Safety" for the ears I guess Laughing But without testing the headphone output of another make of phone I have no way of proving whether you could consider it a design fault of the car. I do know that on my old 2003 FFRR when I swapped out the radio tuner for the BMW version with aux input and you had an adjustable input gain from 1-6, this is not possible on newer FFRR models.
Post #65057 20th May 2011 4:12pm
