![]() | Home > Technical (L322) > Iphone to aux |
Neil E Member Since: 05 Jan 2010 Location: North West Posts: 60 ![]() ![]() |
Hi all,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
afaik the aux is for output only, not input.. |
christ! no wonder then!
not sure but there is loads on this subject here somewhere .. |
thanks I`ll take a look through forum. MY21 P400e AB
You can input via the aux I am pretty sure as I have done so with my Blackberry sounds files.... |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
![]() ![]() ![]() Sorry scarey, I have to disagree - the 3.5mm aux "input" socket in the rear centre panel on D3,D4 RRS & FFRR is for audio input. Looking at the link posted about the cable it appears to have two phono connections? How have you converted this to a single 3.5mm jack plug? For the wife's D3 we bought this: http://www.amazon.co.uk/Kensington-33429EU...B0011UK2HE Works perfectly and charges the iPhone AND has a remote control ![]() I would check that your cable is the right one as it doesn't look compatible to me ![]() ![]() Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone. SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
The 3.5mm RSE jack on my 2006 FFRR is for aux in and allows you to play music through the speakers. The red and white line-in inputs only allow you to play sound through the RSE.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
You can play video through the phono ports in the RSE panel, from your iPod for example. However it only plays on the REAR screens, not the front centre screen.
ZZT Member Since: 02 May 2011 Location: NJ Posts: 3 ![]() ![]() |
The real problem is that mp3 players are designed to drive headphones. Headphones don't need the same signal level as the AUX input. If you are going to use a headphone output, you'll most likely need some type of in-line amplifier. Google "portable headphone amp" or "Sound Shocker Pro" and you'll find lots of info. Almost all need some sort of power (battery or car plug-in) except Sound Shocker. |
Sorry but I disagree.
duka Member Since: 11 Jan 2011 Location: uk Posts: 147 ![]() ![]() |
I'll have a check on my lead, I bought it from ebay for £2.99 & can plug my iphone through the rear 3.5mm aux socket & it plays music without hassle. |
I think we may be straying from the original post which was a concern specifically regarding an iPhone audio out and the correct cable - I was just pointing out that an iPhone has a very low output gain from the headphone socket and because of this the headphone socket is not really suitable to connect to the aux input in Land/Range Rovers! You have to use the main connector at the bottom of the phone which has a much higher audio output gain which works perfectly. Apple have obviously designed their phone that way "Health & Safety" for the ears I guess ![]() Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone. SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
