![]() | Home > In Car Electronics (L405) > Fitting Dash Cam |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
And it’s like they read your mind Stan.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
£11 for a 12v to 5v is a bit expensive but it saves getting separate bits ..
used to be about £1600 apparently, but over the last 6 months the prices of shipping from China has gone through the roof. Saw it on the BBC the other day.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
For all those who need ACC.
Wingers Member Since: 17 Mar 2021 Location: Glasgow Posts: 1 ![]() ![]() ![]() |
I can highly recommend the BlackVue dr900 dual
So today fitted the Powerful tap in loom in the overhead console, I can confirm it works on L405 its now £28 on fleabay its a quick easy instal.
Bimshire Member Since: 23 Nov 2022 Location: Suffolk Posts: 18 ![]() ![]() |
Excellent looking to do this mod when I pick up my new toy next week.... just to confirm you used this tap in loom on a 2018MY as Powerful say these haven't been tested on anything after 2017. Ta. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1854 ![]() ![]() ![]() |
I did mine in 10 minutes with the Powerful UK Kit, all plug-and-play now:
Thanks Gremlin, I'll be fitting my 2019MY AB with a Blackvue which uses 12v so I'll be ordering the basic one.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
I'd do some research on the Bloackvue. I had one on my 2018 car and I kept getting a Low Battery warning, even set at it's lowest setting.
I'll be using a newer X model without a Powermagic box, looks like you can set battery protection to 11.8V, 12V, and 12.5V. I plan to start at 12.5V
The LR is very good though and simple to use. I had problems with the Blackvue and found it not so user friendly All LR cars from 1984
Yes mine is a MY18 2018 SE SDV8 4.4 Byron Blue |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
Tanks to the OP for this useful post.
