![]() | Home > Maintenance & Mods (L405) > Executive rear seat storage lid fatal demise |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
Mine also have broken. I was told that the whole part needs to be replaced. Cost of 700€ plus. So I didn't investigate more. But will be interested in where you get with this. SDV8 AB MY 2020
Bimshire Member Since: 23 Nov 2022 Location: Suffolk Posts: 18 ![]() ![]() |
I’ve looked at 2 approved used in the past month and both had broken hinges. The second dealer said he already had some on back order for a customer so I took the plunge and bought it anyway assuming it’s a regular thing that breaks and asked them to order me a set. Price seems steep even for LR. MY19 SDV8 Autobiography
Did you get the part number? How much? I might think about doing the replacement. Need to find out how to take it apart. SDV8 AB MY 2020
No, I’m waiting for the dealer to reply to my email as the handover was done by someone else so when they reply I’ll post the info here MY19 SDV8 Autobiography
Have you got the new hinges? SDV8 AB MY 2020
Just wondering if you got any reply. I will try and ask when I drop the car in for its service car. SDV8 AB MY 2020
No I never got the part before I rejected the car, too many faults which they couldn’t diagnose. MY19 SDV8 Autobiography
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 536 ![]() ![]() |
mine is an approved used and it had broken too, the lid had been bonded shut by someone, I didnt find out for ages after buying it so cant take it back to them. I'd be interested in a cheapish fix otherwise I'll leave it shut Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
Swagman Member Since: 03 Mar 2025 Location: Northampton Posts: 5 ![]() ![]() ![]() |
Just bought mine and when I got home found mine broken as well, seems like a part that snaps easily judging by the comments above, but with no fix? |
Mine was replaced under warranty in the end. The part for me was LR123412.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2712 ![]() ![]() ![]() |
Mine has come apart from the front whilst moving the seats up and down . Was told by main dealer there are no repair parts , only to replace the entire arm rest , over £6k for it … I decided to keep it deployed as I can’t see the broken bit . 2019 SV AB Dynamic Scafel Grey |
Ohh, I may have to look into that as although the car is nearly 6 years old, it has come with a years Landrover warranty as a approved used car, but if I have no joy there, I also think if I can find a plastic tube that is the correct diameter to 'snap' over the metal cylindrical parts in the base by cutting a slot in the tube I could epoxy that to the underside of the lid (in the hinge position, I may be able to fashion a repair. (just thinking out loud ![]() |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1508 ![]() ![]() ![]() |
If you cant purchase parts then why is this showing availability and parts?? admittedly they are expensive but on the face of it appears you can purchase all the required parts.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2733 ![]() ![]() |
Land Rover has been known to stop making smaller parts available individually, instead supplying the major component especially if a design change has occurred. L405 D350 SE Carpathian Grey D5 19" rims |
