Home > Maintenance & Mods (L405) > Executive rear seat storage lid fatal demise
Page 3 of 4 <1234>
Swagman
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Siberian Silver
Luckily it's still absolutely fine, those metal ties hold on pretty tight and with some epoxy around them for good measure it's a pretty solid fix, it grips onto the metal pivoting parts whilst actuating the lid without any slipping..
Post #719532 10th Jun 2025 12:18pm
noone
United States
Good to know!! And it looks like it’s all hidden which is great. 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #719533 10th Jun 2025 12:24pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
The plastic on the top lid failed. Not sure if the metal bits they go around are meant to move. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #719551 10th Jun 2025 6:07pm
luxmoggy
The new one SDV8 AB MY 2020
Post #719552 10th Jun 2025 6:11pm
noone
United States
Thx. So it’s the plastic lid under the leather armrest top. Appreciate you taking a picture of it. I would buy the part if it was available, but I can’t find it. Guess I’ll have to MacGyver it with metal zip ties and epoxy. 2023 L460 Range Rover SE P400
Post #719572 11th Jun 2025 2:39am
CerebralThunder
Did something similar to @Swagman, seems to be holding. What a ball-ache though..
 2021 L405 Range Rover 'Fifty' D350
Post #719611 11th Jun 2025 5:09pm
noone
United States
Did you epoxy it after you zip tied it together? I’m thinking I can use plastic zip ties, tighten them super tight with rolling a needle nose pliar, then dab epoxy on all sides.
I did end up finding a lid but they want $600 for the part. I would rather spend that on a front lid which actually is showing wear from arms being on it all the time. 2023 L460 Range Rover SE P400
Post #719617 11th Jun 2025 6:20pm
CerebralThunder
I just put the 2 halves together for each section and zip tied them with the metal ties. I have a metal tie gun that I used to make sure they were very tight (and it cuts them flush). 2021 L405 Range Rover 'Fifty' D350
Post #719624 11th Jun 2025 8:50pm
noone
United States
Is this the one to buy? Will the zip tie connection clear the bottom when the lid pivots up? https://www.amazon.com/FACTORAY-Stainless-...8&th=1 2023 L460 Range Rover SE P400
Post #719628 11th Jun 2025 9:15pm
CerebralThunder
Mine is more like this (it's more expensive but I have access to them with my job):
Tie doesn't impede anything as far as I can see. 2021 L405 Range Rover 'Fifty' D350
Post #719630 11th Jun 2025 9:47pm
noone
United States
Thx. And I assume the metal zip ties are all one size it looks like. I just need the tool to last 4 times of zipping. 🥴 2023 L460 Range Rover SE P400
Post #719631 11th Jun 2025 10:06pm
Swagman
Nice neat job @CerebralThunder,
Glad you had the correct tool, I considered buying one, but in the end just rolled them over some thin nosed pliers, that's why I used some extra epoxy as although they seemed pretty tight to me, doesn't hurt to double down with some extra gloop, but your right it is a bit of a faff!
Post #722343 5th Aug 2025 10:05am
noone
United States
How did you remove the center console? By unscrewing/unplugging the whole thing? Or just the lid? 2023 L460 Range Rover SE P400
Post #722353 5th Aug 2025 12:11pm
Swagman
Just the lid and the tray under it, once you've unclipped the leather covering it (that is attached to the rear boot panel), you'll see a couple of screws
Post #722367 5th Aug 2025 5:04pm
noone
United States
Thx, stupid question but how does it unclip? Do you have a picture of the flap? Are there two folds on the leather piece and I just push/pull it through? 2023 L460 Range Rover SE P400
Post #722374 5th Aug 2025 5:39pm
Page 3 of 4 <1234>
