![]() | Home > In Car Electronics (L405) > Map Updates not Updating |
| Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802
It might not be the same, but I tried to update the maps a couple of times without success, then it worked when I:
| Spleen Member Since: 11 Feb 2022 Location: Wilts Posts: 97
Cheers, that's exactly what I've done previously but it's just not doing anything now, I'm completely perplexed. Going to reformat the drive and try again. 2017 Vogue SE
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1894
………. V6 Vogue - “Less is More” - less to go wrong! |
Cheers Gremlin. I use a MacBook and I'm now downloading the files again after reformatting. Interestingly (and I use the word loosely), i reformatted it to FAT 32 using disk utility but when I went to download the maps it said the stick wasn't formatted properly and would I like to reformat. Done that (again) so let's see what happens.
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
You can format as FAT (actually, FAT16) if the size is 4GB or less, if your USB stick is bigger use the DISKPART command. |
Nope, not having it. Reformatted it and redownloaded the files but nothing. Sigh. 2017 Vogue SE
Aye, it won’t let you download anything unless the drive is reformatted by the tool anyway so it’s original state is largely irrelevant. I can download it just fine, it’s just that the car isn’t picking it up. Brand new 64gb, not used for anything else. 2017 Vogue SE Ferrari F430 F1 Spider |
No idea to be honest, don’t own a voltmeter. Tailgate fine albeit that it thumps rather than gently closes. ‘They all do that sir.’ Not on my wife’s RRS it doesn’t. Dealers.
Try a smaller USB stick, it may be too large to be recognised properly |
Still no luck, bored with it now. I'll see what happens when I download a Jan 23 update and go from there. As an aside I just got back from a 2500 mile jaunt down to Croatia and back, no static camera alerts in France or Germany now. 2017 Vogue SE
My God, this is bloody frustrating. I decided today to delete the car from the IC Route landrover.here.com site and reregister but will it let me? Will it |
| All times are GMT |
