Home > My Range Rover > Finally, A Full Fat. |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1087 |
The threads should be dry at 140nm if you put on grease etc you will over torque them
12th Jan 2023 7:06pm |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 314 |
Ooo might try the ACF50, hopefully keeps these nice and "new"
hmm tbf torquing to 140nm and probably plenty of room to overtorque given how tight they were before. I mean I literally had to deadlift the breaker bar with both hands for some of them. i sprayed with WD40 for now. tbf just leaving at 140nm will probably be enough. Its actually a sport Not anymore, 4.4 TDV8 now |
12th Jan 2023 7:34pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2639 |
+1 There is a lot of force going through these studs with these big wheels (some other 4x4's have 6 studs). If you grease them they will not be secure and the torque needed to secure them with grease with stretch the studs. If you are worried about them seizing just go round them every so often loosening and retorquing them. Infact you should be doing this anyway on any car. 2012 TDV8 Vogue (L322) |
12th Jan 2023 7:55pm |
tbf ive never had this problem with any other car.
12th Jan 2023 7:58pm |
Were they tight due to over tightening or due to corrosion? 2012 TDV8 Vogue (L322) |
12th Jan 2023 8:03pm |
I'd say both.
12th Jan 2023 8:13pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Breakaway torque is higher than tightening torque, there is a calculation based upon many factors, I'd guess it's north of 180Nm for Landrover wheel nuts.
12th Jan 2023 9:28pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
@Pheonix:
12th Jan 2023 9:48pm |
Thanks, some manufacturers (Audi for one) do specify a lubricant for the wheel studs (or bolts, I forget which they have), it's not any old grease or oil though, and the torque is a bit lower than other VWG vehicles that use the same parts for the hubs & nuts/bolts.
12th Jan 2023 10:08pm |
Well I guess when I've got wheels off I'll give em a good clean and torque em right and probably acf50 the wheel nuts to avoid swelling.
12th Jan 2023 10:54pm |
If your worried about corrosion on the threads, it might be OK to use a low-strength Loctite type product as a barrier, however this would need to be researched carefully: in its liquid state I suppose its still acting as a lubricant, however poor.
13th Jan 2023 11:15am |
Tbf this car was next to the seaside before. Now its in the heartland of Leeds. So unsure if rust will be hte same type of problem here? Its actually a sport
13th Jan 2023 11:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
will that panel you're selling not fit in your FF...obviously a bit of fettling will be required.. ... - .- -.
13th Jan 2023 12:01pm |
Am guessing it will as a double din. But it won't look as nice as the icebox version. It worked in the RRS because am guessing it was central
13th Jan 2023 12:38pm |
