![]() | Home > Maintenance & Mods (L322) > 5.0 Supercharged - why the stick? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3945 ![]() ![]() ![]() |
Deleted Geoff |
Ive never seen a 6sp with the rotary shifter sir... |
I was gonna say what Craig said - but are 6spds mechanical change rather than electronic - I might be wrong (often am) |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3324 ![]() ![]() ![]() |
Some would have liked the stick retained for the 8speed. 2012 TDV8 Vogue (L322) |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
this Jag was the one that made me wonder 2011 5.0 https://www.pistonheads.com/buy/listing/14...d%20search It says 6 speed, need to cross check that Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Found an Evo review from Harry himself:
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
There are both 'M' and 'E' versions of the ZF6HP boxes, 'E' versions using 'shift-by-wire' rather than a conventional cable; so they can have gear selection by button, rotary, electronic stick, paddles, etc.
Dan! Amazing knowledge
Yeah, 'E' version boxes were fitted to a lot of BMW models and I believe some Audi, Lexus models as well - and probably many others. They're all controlled via CANBus commands rather than electronic switching and a park-brake cable. The mechatronics units have an additional solenoid for Park selection, and the pressure pathways can differ as can the spring specifications for some of the valving.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
You’ll just have on “stick” with it |
