Home > Maintenance & Mods (L322) > 5.0 Supercharged - why the stick?
GGDR
I'd like to switch to a 5.0 L322 due to evil ULEZ.
Fine but one thing that I couldn't go back to is the stick shifter. Which was introduced on the 5.0 L405 but I think this has the 8-speed.
I know the 5.0 L322 has the ZF 6-speed, not the 8-speed so I thought that was the reason why the stick is not fitted.
Until I saw a Jag XJ 5.0 which had the rotary dial and it has the 6-speed box apparently. So they do go together.
So I wonder could the rotary shifter be modded into a 5.0 L322 ??
. Cheers, Greg
Post #654730 25th Jan 2023 10:21pm
supershuttle
Deleted Geoff
Post #654741 25th Jan 2023 11:01pm
Ive never seen a 6sp with the rotary shifter sir... Confused
Post #654749 26th Jan 2023 2:34am
supershuttle
I was gonna say what Craig said - but are 6spds mechanical change rather than electronic - I might be wrong (often am) Very Happy Geoff
Post #654751 26th Jan 2023 8:14am
JayGee
Some would have liked the stick retained for the 8speed. 2012 TDV8 Vogue (L322)
Post #654753 26th Jan 2023 8:19am
GGDR
this Jag was the one that made me wonder 2011 5.0
https://www.pistonheads.com/buy/listing/14...d%20search
It says 6 speed, need to cross check that Cheers, Greg
Post #654763 26th Jan 2023 10:27am
GGDR
Found an Evo review from Harry himself:
https://www.evo.co.uk/jaguar/xj/6912/jaguar-xj-50l-v8-review
Quote:
Jaguar XJ 5.0L V8 review
Forget the controversial looks - the new big Jag is one of the best drives in its class
by: Harry Metcalfe
18 Apr 2010
....And when you elect to control the six-speed automatic gearbox manually...
 Cheers, Greg
Post #654764 26th Jan 2023 10:31am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
There are both 'M' and 'E' versions of the ZF6HP boxes, 'E' versions using 'shift-by-wire' rather than a conventional cable; so they can have gear selection by button, rotary, electronic stick, paddles, etc.
Totally different mechatronics units, gearbox control units, shift strategy software, mechanical parking brake engagement method, etc.
*HUGE* amount of work to retrofit 'E' to 'M' cars. Can be done, but not really worthwhile if the reason for doing it is just not being a fan of the stick.
Post #654765 26th Jan 2023 10:32am
GGDR
Dan! Amazing knowledge
So the Jag probably has the 'E'. and the Range Rover probably has the 'M" ??
I'll dig around Smile
. Cheers, Greg
Post #654767 26th Jan 2023 10:45am
Danb_220_2019
Yeah, 'E' version boxes were fitted to a lot of BMW models and I believe some Audi, Lexus models as well - and probably many others. They're all controlled via CANBus commands rather than electronic switching and a park-brake cable. The mechatronics units have an additional solenoid for Park selection, and the pressure pathways can differ as can the spring specifications for some of the valving.
It's important to note that *none* of the 6HP transmissions have an old-fashioned P,R,N,D,1,2,3 cable-operated gear selector; rather, the operating mode is selected by a combination of electronic switching from the manufacturer's chosen operating method (stick, etc) with a manual 'P' selection via traditional cable. The 'E' versions of the transmission replaced that traditional cable with a solenoid operated parking brake mechanism, but also reduced the number of active electrical connections that can be used for gearbox signalling; such that all the signalling including things like shift-locking, ignition interlock and manual shift demands are done by CANbus messaging.
The 6HP26 was definitely fitted to Jaguar models, although I'm not sure which ones.
Some interesting documentation in the PDF I've shared here:
https://1drv.ms/b/s!AgN0ZfQ6h19_htMcHocBfhVWWIv2QQ?e=RQ4VkF
Post #654769 26th Jan 2023 11:17am
DrRob
You’ll just have on “stick” with it Whistle Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654773 26th Jan 2023 1:43pm
