![]() | Home > Maintenance & Mods (L322) > 5.0 Supercharged - why the stick? |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
Deleted Geoff |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Ive never seen a 6sp with the rotary shifter sir... |
I was gonna say what Craig said - but are 6spds mechanical change rather than electronic - I might be wrong (often am) |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3396
Some would have liked the stick retained for the 8speed. 2012 TDV8 Vogue (L322) |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
this Jag was the one that made me wonder 2011 5.0 https://www.pistonheads.com/buy/listing/14...d%20search It says 6 speed, need to cross check that Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Found an Evo review from Harry himself:
| Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262
There are both 'M' and 'E' versions of the ZF6HP boxes, 'E' versions using 'shift-by-wire' rather than a conventional cable; so they can have gear selection by button, rotary, electronic stick, paddles, etc.
Dan! Amazing knowledge
Yeah, 'E' version boxes were fitted to a lot of BMW models and I believe some Audi, Lexus models as well - and probably many others. They're all controlled via CANBus commands rather than electronic switching and a park-brake cable. The mechatronics units have an additional solenoid for Park selection, and the pressure pathways can differ as can the spring specifications for some of the valving.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
You’ll just have on “stick” with it |
