Home > Technical (L322) > Replace entire aux heater?
cattona
My FBH doesn't work, fault code says the water pump of the fuel burning heater is defect. I see some offered on eBay for something like 150quid. If I buy one of those used units, do they include that pump, or is that a separate item? Does anyone have experience in having had this issue?
4.4 TDV8 2011 2011 L322 Vogue SE 4.4 TDV8
Post #582840 8th Feb 2021 5:18pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Separate item I believe, have a look on lr cat in wiki section.
Post #582891 8th Feb 2021 10:19pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I also have a similar code on my 4.4.
B12A6-15 (2f)
Aux heater water pump- general electrical; failure - circuit short to battery or open.
My FBH sounds like it starts and can run several times over but never gets warm.
You can hear the pump running but I've not checked if it is pumping.
You can buy new pumps fairly cheap.
Post #582894 8th Feb 2021 10:26pm
DrRob
JNC - did a new pump solve your FBH issue? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657741 25th Feb 2023 3:50pm
JNC
Yes it did.
I got a slightly different pump. Needed to swap the inlet/outlet part and the plug. (Not sure if i was sent wrong pump or ordered wrong but i just made it work)
But once fitted, fixed the issue.
Edit -
I originally thought it was the pump in the engine bay (you could hear this running) as i wasn’t aware fbh had its own.
But it was the pump attached to the FBH itself.
Post #657742 25th Feb 2023 3:54pm
DrRob
Excellent! Cheers 👍
I think this is the one
https://www.ebay.co.uk/itm/Water-Pump-for-...635-2958-0
18B483 on JLR schematic
https://parts.jaguarlandroverclassic.com/j...water.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657744 25th Feb 2023 3:55pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Post #657779 25th Feb 2023 6:39pm
DrRob
Is that the part I assume? Did you fit that to fix the same fault code?
Details please Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657814 25th Feb 2023 9:55pm
jaguar3
No, I had another problem (combustion chamber death). I replace Webasto compleatly, install brand new. This pump is from old original factory Webasto.
Part nr 9017986a
This is my old Webasto, including the pump.
Post #657816 25th Feb 2023 10:09pm
jaguar3
DrRob wrote:
Excellent! Cheers 👍
No, this is another pump, not belongs to Webasto. This pump is for increase coolant flow during idle rpm. Also when use AC MAX option when engine stop to pumping residual engine heat into the cabin.
Those two pumps are different. As I understood you need to change Webasto pump, then you need same as on my pictures.
Post #657821 25th Feb 2023 10:57pm
DrRob
JNC - can you clarify this as I’m now confused. Did you change the little pump bolted to the exterior of the FBH to cure your issue? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657860 26th Feb 2023 2:34pm
JNC
Mine was the pump attached to the FBH.
Post #657874 26th Feb 2023 6:54pm
DrRob
Great 👍 As I thought 👌 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657904 26th Feb 2023 8:45pm
DrRob
Pump being replaced this week with a Genuine part. Will report back Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658786 7th Mar 2023 6:25pm
DrRob
All fixed with a new pump
https://www.fullfatrr.com/forum/topic66151.html
Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #659075 10th Mar 2023 9:13pm
