Home > Technical (L322) > Replace entire aux heater? |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Separate item I believe, have a look on lr cat in wiki section. |
8th Feb 2021 10:19pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I also have a similar code on my 4.4.
8th Feb 2021 10:26pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4252 |
JNC - did a new pump solve your FBH issue? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Feb 2023 3:50pm |
Yes it did.
25th Feb 2023 3:54pm |
Excellent! Cheers 👍
25th Feb 2023 3:55pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
25th Feb 2023 6:39pm |
Is that the part I assume? Did you fit that to fix the same fault code?
25th Feb 2023 9:55pm |
No, I had another problem (combustion chamber death). I replace Webasto compleatly, install brand new. This pump is from old original factory Webasto.
25th Feb 2023 10:09pm |
No, this is another pump, not belongs to Webasto. This pump is for increase coolant flow during idle rpm. Also when use AC MAX option when engine stop to pumping residual engine heat into the cabin. Those two pumps are different. As I understood you need to change Webasto pump, then you need same as on my pictures. |
25th Feb 2023 10:57pm |
JNC - can you clarify this as I’m now confused. Did you change the little pump bolted to the exterior of the FBH to cure your issue? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Feb 2023 2:34pm |
Mine was the pump attached to the FBH. |
26th Feb 2023 6:54pm |
Great 👍 As I thought 👌 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Feb 2023 8:45pm |
Pump being replaced this week with a Genuine part. Will report back Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Mar 2023 6:25pm |
All fixed with a new pump
10th Mar 2023 9:13pm |
