Home > Technical (L405) > front knuckle cracking
Page 17 of 57 <123 ... 161718 ... 555657>
dont worry, i'm going to put all these related threads as 'stickys' so they will be at the top of the page... ... - .- -.
Post #658513 5th Mar 2023 9:44am
knwatkins
Gremlin500 wrote:
Sadly, it will take a death before JLR do anything about it, shame on them.
Am I right it seems to be only 2015/2016 cars affected by this? Or does it extend further either way?
Without a bit of transparency from the manufacturer, I guess we might never know, due to the cover up culture in this country from politicians and big business alike. Sad
I am not sure we can say there is cover up or lack of transparency on this. Land Rover have recognised the problem and published that the affected VIN range is 195780 - 228236.
They have started doing recalls in other countries but yes, if it takes a death for them to do anything about it in the UK due to the lack of litigation culture, this is shameful.
Fenair, comiseraitions for you. It's a bit of a disaster. But I'm glad to read that you and your family are safe and well. Like you say, it could have been a whole lot worse. Fortunately, these failures seem to happen when turning sharply at low speed, touch wood. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #658520 5th Mar 2023 10:47am
CS
The minister responsible for DVSA is Richard Holden, MP for NW Durham. With Canada (and maybe also the USA) doing a recall on this LR are clear about the need for it, but are doing nothing in the UK either because they don't have the parts or they just want to avoid spending the money. There seems a case for lobbying Richard Holden to get DVSA to force the pace on this. I think one cannot email direct, it has to be through constituency MPs, but they will pass the matter on pretty promptly. It would probably have most impact if done by someone actually affected, but anyone concerned about this important safety issue could do so. Only Range Rovers since 1988
Post #658521 5th Mar 2023 10:49am
dingg1
Kot
You need to have another think about mpi being no good for alumium alloys šŸ˜Ž
Post #658522 5th Mar 2023 10:53am
fenair
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
My vin is 2186** SDV8 2015
Post #658525 5th Mar 2023 11:19am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
richard.holden.mp@parliament.uk BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #658528 5th Mar 2023 12:12pm
Mikey
Evoque/DS steering rack recalls started in Canada, then eventually made its way to the UK. And our customers who we replaced racks for before the recall was active have been receiving refunds from JLR Thumbs Up
Keep the pressure on JLR, with enough pressure, they might just recall it in the UK too Thumbs Up
Post #658531 5th Mar 2023 12:37pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
[/quote]
[/quote]
Kev - where is this published please?
cheers 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #658539 5th Mar 2023 3:51pm
Gremlin500
@knwatkins:
Fair comment, I didn’t specifically mention JLR, just the culture in this country to bury heads in sand and ignore issues until they are pressing. Knowing there is a problem, and doing nothing about it is negligent, espicially when lives can be lost, think about Grenfell. V6 Vogue - ā€œLess is Moreā€ - less to go wrong!
Post #658542 5th Mar 2023 4:24pm
knwatkins
cheers
It's in bulletin N036. I only have a copy in Russian, but someone on here with access to Topix may kindly download it for us? Bow down
Here's a link to the N306 bulletin in Russian.
It is mentioned in this Russian video at 1:36 ....
 Kev
Post #658554 5th Mar 2023 5:31pm
Kot
dingg1 wrote:
Kot
Quote from link regarding misconceptions about mpi
It is amazing how many people think this type of testing will work on any kind of metal. In truth though, it is generally only appropriate for metals that can be magnetised. That includes ones like iron and nickel, as well as a number of alloys that contain them such as types of steel.
https://www.formatndt.co.uk/a-look-at-some...-about-mpi
also https://www.bindt.org/What-is-NDT/Magnetic...ction-MPI/
Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #658574 5th Mar 2023 7:54pm
dingg1
Here's another quote for you
https://medium.com/@globalweldingau/miscon...b92fe51895
"When you’re looking to use Magnetic Particle Testing try to understand the composition of the parts. Not every metals can undergo the process of MPI. This is because, only iron, nickel and cobalt can be magnetized. An alloy metal can also undergo this process, one such example is aluminum. It is also one of the most common metals that is tested with MPI."
Me retired from oil and gas industry
Previously commercial diver
Cwsip 3.1u
Cswip 3.2u amongst others šŸ˜Ž
Post #658584 5th Mar 2023 9:55pm
Gremlin500
Ummmm, sorry to be a little pedantic but aren’t we drifting just slightly OT here, gents?
Rather than discussing the limitations of MPI, shouldn’t we be discussing the extent of the current situation with respect to knuckle failures Worldwide, and the lack of UK response to our valid concerns from either JLR or UK government?
I don’t think we need MPI or other tests to prove anything, there are documented failures which clearly prove parts have failed, potentially putting lives at risk. It is up to the vehicle manufacturer to prove that all affected vehicles have been abused or malmaintained in some way, and in fact, given that most of the affected vehicles will likely have a FLRSH, it again possibly would reflect back at lack of JLR service training in any case, were that to be the situation.
This is potentially an eventual lose-lose situation for JLR, and I wonder what if any design changes have been made to the same part in the new L460, -anyone with a new vehicle got any pics? A change would tend to point at an admission of some sort, and conversely by implication, a lack of change would not show the L460 in good light as a potential purchase, if that is so.
An informative statement from JLR in the interests of transparency would be most welcomed by current owners and potential purchasers alike, I’m sure. V6 Vogue - ā€œLess is Moreā€ - less to go wrong!
Post #658587 5th Mar 2023 11:18pm
GraemeS
Australia
The original part numbers have been superseded 4 times so I suspect that LR has been aware of shortcomings in at least earlier versions.
Post #658593 6th Mar 2023 1:22am
dingg1
Of course you're correct Gremlin šŸ‘šŸ¤“
Although it appears that jlr are waiting for a catastrophic major event before taking action in the UK. I'm astounded by the inaction tbhšŸ˜ž
Post #658599 6th Mar 2023 8:59am
