![]() | Home > Technical (L405) > front knuckle cracking |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
If you want to go the cheap Chinese route then buy them from Rangeroverworlds suppliers, loads on AliExpress starting at £200...
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
They look identical to the Britpart offerings... |
| Extol Member Since: 13 Jan 2024 Location: London Posts: 20
Now I have done both my 2016 L405 knuckles, few things I did do/change.
Hope this is any help |
| chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 159
Stainless steel and alloy do not work well together. |
Thank you, and much appreciate the advise, I thought my protective coating will stop the water getting in. I could be wrong, but I shall keep an eye. |
When using dissimilar metals you need some form of barrier, not a coating done after assembly... I use Tef Gel, used widely in the marine industry.... |
| Robbie993 Member Since: 07 Jul 2024 Location: Praha Posts: 4
Not very good. My car is in the VIN range. I noticed this crack while travelling, and left the car at a Land Rover dealership in The Netherlands. And took a plane home. Didn’t want to drive this suicide machine on the German highway home of course. The dealer contacted me today.. inspected the car and noticed the crack.. They told me they have never seen this before (yeah right..) and the recall only applies to the USA. Quoted 1600 euro for both sides. And then revoked the quote because this was only labour costs and forgot to include the parts. In total they expect 3500-4000 euro for both sides.. I will call the JLR Czech Republic, where my car is registered. Hopefully they will be reasonable. Keep you posted. By the way I was planning to buy the L460. I put this on pause now, depending on how JLR solves this issue since it is really dangerous these knuckle cracks. |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
Mikey posted this on the prior page - seems to clearly state its a global recall, so maybe quote the reference number when asking ?
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
Seems to still say 2014-2016 Got - 2017 SDV8 Autobiography in Loire Blue
hMany thanks for notifying, and will mention it should be global. Keep you updated about the process. |
| Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 120
And another one!
hopefully you will have more joy, than what I had from the JLR with my late 2016 .
| goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 107
[quote="Abacus405"]And another one!
| All times are GMT |
