![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
Thanks for the clarification Graemes.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2749 ![]() ![]() |
If the steering weight changes with a cold start of a module then I suspect there's a programming bug, possibly in the module responsible for the steering but also possibly with another module that the steering module relies upon for data. You might want to check for any outstanding module updates. |
You could be right Graemes, I'm not sure how I can check that though as I do not have an IID tool these days.
Ah |
Just filled up with fuel from virtually empty and straight away the ride has gone much firmer and the steering has weighted up.
Just been reading over on the D3 forum and although it's a different car it seems I am not alone. (Well me, ffrr lover and others etc)
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 136 ![]() ![]() |
Wow that deffo let go. You replacing it with OEM or something else? X5 40d |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
Craig only uses genuine parts..... |
Could these CAN communication codes have anything to do with my issues? |
Could these codes have anything to do with my issues? |
Genuine JLR rear shocks are on order so should be here tomorrow... ![]() |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
Been thinking about this and a couple of thoughts.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
If I were pulling my hair out like you are I’d be taking it to a specialist who works on them daily so that they can give you their thoughts on it.
