![]() | Home > Technical (L405) > Range Rover L405 wont start when engine is hot |
Happy Jim Member Since: 02 Apr 2023 Location: Wokingham Posts: 4 ![]() ![]() |
I had exactly this on a Merc a few years ago, the Crank sensor was the culprit (fine when cool/cold, dead when hot).
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Have you had it plugged into a diagnostic machine to see if any codes are stored? If not that would be your starting point. These are complicated beasts and you could waste £1000’s trying to guess the fault.
Steven_Armit Member Since: 03 May 2023 Location: Shotts Posts: 4 ![]() ![]() |
yes plugged it in nothing coming up and the data when running looks fine |
was thinking down the lines of crank or cam sensor just to see if anybody else has had the same issue and its been something else |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
Monitor the engine rpm during cranking to confirm the status of the crank angle sensor. If no rpm then the crank angle sensor isn't working. |
our snap on machine doesn't seem to give you rpm in the data for some reason al give it another go again tomorrow and see if its in another module |
