Home > Technical (L322) > 4.4 tdv8 started smoking. |
Rusty Nuts Member Since: 06 Jan 2021 Location: Shropshire Posts: 17 |
Hi Kevin ,
20th Mar 2023 7:20pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
From a fair bit of reliable feedback I would go to Clarkes all day long. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
20th Mar 2023 9:02pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Glad you seem to have gotten to the bottom of your issues KevinP... These things can be very unnerving can't they... |
21st Mar 2023 1:14am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1113 |
Thanks Craig. It was very unnerving at the time as it had never done it before.
21st Mar 2023 8:26am |
Well it's got a lot worse even to the point of smoke still coming out the exhausts when stationary if I've revved it past 2500rpm.
10th May 2023 3:41pm |
Keep us posted 👌 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
10th May 2023 7:18pm |
Never had to top up oil before, just checked the level before I go to Clarkes and I've had to put 3 litres in!!
11th May 2023 1:08pm |
That's a lot of oil to lose.
11th May 2023 2:35pm |
No Rob. Needs new turbo's. £6500. Engine out job.
11th May 2023 2:55pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2664 |
Vey unlucky to have the turbo's let go on these although it's the 2nd time this month -
11th May 2023 3:05pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 648 |
I check my oil every week, but it is a pain to open the bonnet and then get back in the car just to enter the service menu on the TFT screen and see if all is well
11th May 2023 3:37pm |
No need to open bonnet. Check it cold in morning. Should be one or two notches above mid line. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
11th May 2023 3:47pm |
The last time I drove it there was no low oil warning!! I would have expected one giving the amount I had to put in.
11th May 2023 3:50pm |
You can put reconditioned turbos on instead of new Genuine if that’s what they’re quoting 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
11th May 2023 3:51pm |
