![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1007 ![]() ![]() ![]() |
might be worth drilling a very small hole in the exhaust ( of the compressor ) , that is something a lot of us have done to get the suspension working again at double quick speed
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
My understanding is that the reservoir is there to avoid having to always run the compressor while making fine height adjustments while driving. 1-step height changes should be mostly accomplished using the reservoir unless within a minute or 2 of a previous change or performing a 2-step change, ie from access to off-road height. My L322 is parked at access height to fit under a low carport but it only takes a couple of seconds to raise to normal height. |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
Okay so are we saying this is a fault then?
Far too long. |
Okay, can anyone take a look at their gallery pressure when raising between access and normal heights?
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 ![]() ![]() ![]() |
Yes, without owning a 405, nearly 30 seconds is way too slow for one height change I'd say.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
Fitted by the main Dealer in March? Get it back to them and get it checked along with everything else surely they can do this??? overfinch modified |
Yes CaymanBlack new compressor fitted to cure air suspension fault.
Think I might have found the problem with the slow to rise suspension.
Another |
Really glad you found a fault BUT, I must say... A competent shop should have found that and would have saved you quite some amount of stress sir... |
I dont know if a leak at the compressor like this could affect ride quality or if it will be improved when this mess up is rectified.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi MarinaWestminster
I think at this point I will wait until this air leak is fixed and the suspension raises at a similar speed to Haylands car before evaluating any ride issues further.
