![]() | Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 303 ![]() ![]() ![]() |
Please could you share the P/N for the radar sensor…. I’m looking for one too. I’m trying to determine if there is compatibility with the RR-Sport or early model L405’s as the device serial numbers are similar but the first few characters are different. The L322 4.4 is BH32-9G768-AD. On the RR-Sport and L405’s the first 4 and last 2 characters are different. I think I read on here that this may refer to the device firmware version. And there’s a procedure for upgrading the firmware with the IID GAP tool. The wiring loom is quite cheap…. £30 or so as I remember. P/N is LR023028 The bracket is quite expensive…. £200. P/N is LR022947 one of the U.K. LR specialists has them in stock. Please update as you go though as I’m also considering this and will be interested how you get on. TDV8 4.4 2012 |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 418 ![]() ![]() ![]() |
From what I can tell they are using the same ones from the L405
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2715 ![]() ![]() |
Gap didn't know if they could flash my Jag unit with L322 firmware but their flashing worked. The Jag unit wasn't recognised as existing in my L322 until flashed.
@mgrover how are you getting on ? I’ve just picked up an ACC sensor part no. BH32-9G768-AD with bracket from eBay. I already have the loom and switch gear so I’m all set to start. TBH I’m apprehensive of the adjustment/calibration procedure so any hints and tips would be appreciated. TDV8 4.4 2012 |
my local dealer has switched their parts department from the local one at the dealer to some centralised order taker.
Line it up by sighting as best you can direct ahead and parallel to the ground should be useful initial aim, then later make minor adjustments if required. Mine's calibration occurred after driving between 2 3-metre or so high steel gateposts, after which the engine has to be switched off, and maybe for a number of seconds as I don't recall the specific procedure, then it was working once the engine was restarted. |
Thank-you! The sensor is due for delivery today so I’ll be cracking on with the job over the next few weeks |
anyone got a spare wire for sale? LR are completely out haha Its actually a sport |
I installed today with the newer bracket.
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
If you have a look at some of the early pages in this topic the guys who first attempted this put up pictures of all the settings they used to get it working. I think you may be missing some of the settings to do with the collision mitigation and braking.
Mine's queue assist worked when tested a couple of times although I don't use it. |
those settings dont show up. do I need to email gap and get an updated version of the firmware? tbf i may need to check if the tool needs updating. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
Have you applied to Gap for full CCF access? |
By full access,
