Home > Technical (L322) > 4.4 tdv8 started smoking.
Page 7 of 8 <12345678>
JayGee
Turbo failure - very, very rare on the 4.4 and no evidence it was connected to the drain system. 2012 TDV8 Vogue (L322)
Post #668696 8th Jul 2023 9:49pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I never said it was connected with the drain system. That said if there’s blue smoke and pre ignition happening, it doesn’t have to go much further to get to runaway state. Once it goes out of control even momentarily the high revs do more damage to the turbos which can then lead to more oil leaking and away it goes to the engine scrapyard after a few minutes of scary uncontrolled RPM. It’s happened to me once with a Ford Mondeo until you’ve witnessed it once you really don’t appreciate just how scary the whole episode is. The Mondeo took about 4 minutes before throwing a rod and bursting into flames. Prior to the runaway it used no oil and there was no smoke, it’s probably why I was really cautious with my fatty when I had the smoke and pre ignition. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #668697 8th Jul 2023 10:06pm
JayGee
No 'pre-ignition' on diesels. A runaway diesel fueled by engine oil needs a significant continuous flow of oil from a failed turbo seal. Seen a disco 1 do it at a road junction manybyears ago. 2012 TDV8 Vogue (L322)
Post #668700 8th Jul 2023 10:42pm
AJGalaxy2012
We will have to agree to differ regarding pre ignition. If theres fuel in the cylinder and the temperature increases sufficiently it will fire, not necessarily at the right time compared to diesel injection which injects diesel at the right time when the conditions in the cylinder are correct for ignition to happen. These conditions are met before the correct ignition angle so if fuel is in there and it fires, the ignition point will be advanced, the relative pinking and knocking will be heard.
You can also witness pre ignition by spraying easy start or similar into a diesel, they knock like crazy. BMW i3 Electric Car
Post #668706 9th Jul 2023 3:53am
JayGee
Probably best to call it a misfire rather than preignition and certainly any combustible substance in the cylinder will do this esp oil. 2012 TDV8 Vogue (L322)
Post #668718 9th Jul 2023 9:30am
AJGalaxy2012
A misfire would be a cylinder not firingf at all rather than firing early? Pre ignition is a much more accurate term for whats happening i.e. ignition taking place before the correct time. BMW i3 Electric Car
Post #668721 9th Jul 2023 9:48am
JayGee
Could also be firing late. 2012 TDV8 Vogue (L322)
Post #668726 9th Jul 2023 10:30am
AJGalaxy2012
What could be firing late? BMW i3 Electric Car
Post #668733 9th Jul 2023 12:26pm
JayGee
Compression ignition. 2012 TDV8 Vogue (L322)
Post #668734 9th Jul 2023 12:31pm
AJGalaxy2012
Sorry but no it cant fire late. Heat is increased as compression takes place, when the heat is such that the flashpoint is reached the fuel ignites. After top dead centre pressure is reducing and therefore temperature reducing. If the oil in cylinder hasnt ignited during compression, theres little (read no) chance of it firing after TDC. Diesel of course is timed to be injected at the appropriate time just before TDC when the heat is sufficient for it to fire immediately. BMW i3 Electric Car
Post #668746 9th Jul 2023 4:45pm
dingg1
Post #668749 9th Jul 2023 5:24pm
dingg1
Post #668751 9th Jul 2023 5:24pm
AJGalaxy2012
I prefer the toffee coated popcorn if you could be so kind. Laughing Laughing Laughing BMW i3 Electric Car
Post #668753 9th Jul 2023 6:50pm
kevinp
Can you two go and argue your theories some where else please!!!!
Seems to me you know nothing what you're arguing about ffs.!!
Post #668757 9th Jul 2023 8:12pm
AJGalaxy2012
It kind of shows how little you understand or perhaps you could share your superior knowledge and explain why I'm wrong.
I will however leave this topic now for the others to decipher the correct information.
Out BMW i3 Electric Car
Post #668758 9th Jul 2023 8:16pm
