![]() | Home > General > What Did You Do In Your Full Fat Today |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299 ![]() ![]() ![]() |
Fitted a new battery today and all is well again.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3340 ![]() ![]() ![]() |
Fitted the spare wheel removing strap system. This should avoid me hurting my back trying to remove the wheel if I get a puncture. Unfortunately I hurt my back removing the wheel in order to fit the straps |
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 187 ![]() ![]() |
Picked it up after having the power steering hoses replaced, happily with original LR parts not aftermarket. |
joel-h Member Since: 23 Sep 2018 Location: Kent Posts: 39 ![]() ![]() ![]() |
Picked up my new front dust shields which I'll be modifying to be "slide on" rather than "hub out"
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
1.Installed a MKIV Navi with 2019 maps. As archaic it may be, it's a far cry from the MKIII and something I can actually use |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Collected from independent. Oil service and replaced air con compressor, condenser,dryer.regas etc. Whilst the front was off had the serpentine belt and tensioner replaced as well.
Flashed a very nice "Range Rover" splash screen on the new MKIV and edited the "BMW ASSIST" into... "JLR ASSIST" |
landy95 Member Since: 04 Aug 2021 Location: West Midlands Posts: 86 ![]() ![]() ![]() |
Completed a service, new oil, oil filter, air filters, cabin filter and fuel filter, in between down pours of rain. Oh and purchased a deployable side step kit. Also own a 1976 Land Rover 101 3.5 V8.
Installed the wiring loom and fully connected it to the various plugs and sockets for my deployable side steps. Steps to be fitted tomorrow. Also own a 1976 Land Rover 101 3.5 V8.
=dj= Member Since: 24 Oct 2020 Location: New forest Posts: 67 ![]() ![]() ![]() |
Got the wheels refurbished in brilliant silver. I'd had them diamond cut previously which looks great for all of about 6 months before the laquer falls apart and the corrosion sets in...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Fitted new rear brake pads and cleaned out the handbrake drums. The handbrake actually works now. |
DannyJeff Member Since: 13 May 2023 Location: Brighouse Posts: 3 ![]() ![]() ![]() |
Finally managed to pin down the slight loss of coolant ( approx 0.2L every couple of months).
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
I have clay barred, machine corrected the paint and then polished the car.
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 466 ![]() ![]() ![]() |
Had the tracking done. Was driving quite true but felt something was a little off, I thought maybe at the back but it was the fronts.
