![]() | Home > Technical (L405) > MY19 deployable side steps |
rstoughy Member Since: 17 Dec 2022 Location: Stonehaven Posts: 27 ![]() ![]() ![]() |
Maybe unplugged?
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 91 ![]() ![]() ![]() |
Thanks RStoughy, do you happen to know where I would find the plug please? 2019 Autobiography SDV8 Byron blue/black - current
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi, Have you checked the fuse's right side rear? The information screen has an on/off button.
Thanks Tinman, I tried the put it in neutral etc but it sadly didn’t work. I found the fuses in the right hand side of the boot but how do you get to them? I have taken a picture.
Hi, it's in the sidewall right side you have to lever it out from the top, mine is number 39, 30amp green.
Hi, have a look here.
Look underneath at the motor end of the step and you should see the big electrical plug sir... Is it plugged in? |
Thanks guys. I will take a look at both of these options. I will let you know how I get on 2019 Autobiography SDV8 Byron blue/black - current
So back from holiday-
noone Member Since: 05 Apr 2025 Location: Florida Posts: 95 ![]() ![]() |
I know this is a few years old, but can you reply with what the dealer did to resolve? Did they have to re-add the deployable steps module via programming? 2023 L460 Range Rover SE P400
The dealer did a software update on the side steps and the restricted performance was down to the turbo actuator that was replaced under warranty. Since then I get the occasional problem with the steps sticking out on the drivers side but a good power washing seems to resolve this and they go back to normal. 2019 Autobiography SDV8 Byron blue/black - current
Thanks, I’ve got an appt scheduled for this Saturday for my steps with the main dealer. I also think a software update should sort it. 2023 L460 Range Rover SE P400
To close the loop in this, exact same problem as described by OP. When the previous owner took it in for service at the dealer in his city, they removed the deployable steps programming by accident. My local main dealer got me sorted and reprogrammed free of charge, which thoroughly surprised me. 2023 L460 Range Rover SE P400
