Home > Technical (L405) > MY19 deployable side steps
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
Hi I have just bought a MY19 RR AB with DSS but I can’t seem to get them to work. On this model year the on/off button is activated on the screen rather than the physical button on previous models. Has anyone any ideas how to get them going or how to reset them please? 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #670332 2nd Aug 2023 6:18pm
rstoughy
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Maybe unplugged?
They could have been sticking and previous owner just unplugged them. Be worth a look.
Post #670356 3rd Aug 2023 7:41am
madasmad
Thanks RStoughy, do you happen to know where I would find the plug please? 2019 Autobiography SDV8 Byron blue/black - current
Post #670372 3rd Aug 2023 1:35pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, Have you checked the fuse's right side rear? The information screen has an on/off button.
You could try putting the car into `N` by turning off the ignition, turning the ignition `on` then trying to deploy, not starting the car. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #670378 3rd Aug 2023 2:40pm
madasmad
Thanks Tinman, I tried the put it in neutral etc but it sadly didn’t work. I found the fuses in the right hand side of the boot but how do you get to them? I have taken a picture.
Post #670403 3rd Aug 2023 9:56pm
Tinman
Hi, it's in the sidewall right side you have to lever it out from the top, mine is number 39, 30amp green.
The module is located in the spare wheel area after you take the cover from under the wheel's left side, it's in the same bracket as the rear seat module.
It may help if you look up how to install deployable steps as I fitted mine, that's how I know. 2017 SDV8 4.4 silicon silver AB
Post #670418 4th Aug 2023 9:29am
Tinman
Hi, have a look here.
https://accessories-instructions.landrover.com/enUSA/range-rover 2017 SDV8 4.4 silicon silver AB
Post #670420 4th Aug 2023 9:56am
Look underneath at the motor end of the step and you should see the big electrical plug sir... Is it plugged in?
Post #670427 4th Aug 2023 10:57am
madasmad
Thanks guys. I will take a look at both of these options. I will let you know how I get on 2019 Autobiography SDV8 Byron blue/black - current
Post #670430 4th Aug 2023 12:03pm
madasmad
So back from holiday-
I checked to see that the steps are plugged in and they are. So not sure what to do next?
Censored Also now had the dreaded “ok to drive with caution- restricted performance”! Checked all the hoses I can see and nothing obvious. Perhaps software like my previous one?
Dealer cannot fit me in for a month Big Cry 2019 Autobiography SDV8 Byron blue/black - current
Post #671278 16th Aug 2023 12:08pm
noone
United States
I know this is a few years old, but can you reply with what the dealer did to resolve? Did they have to re-add the deployable steps module via programming? 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #722016 29th Jul 2025 12:05am
madasmad
The dealer did a software update on the side steps and the restricted performance was down to the turbo actuator that was replaced under warranty. Since then I get the occasional problem with the steps sticking out on the drivers side but a good power washing seems to resolve this and they go back to normal. 2019 Autobiography SDV8 Byron blue/black - current
Post #722080 30th Jul 2025 10:14am
noone
United States
Thanks, I’ve got an appt scheduled for this Saturday for my steps with the main dealer. I also think a software update should sort it. 2023 L460 Range Rover SE P400
Post #722099 30th Jul 2025 5:35pm
noone
United States
To close the loop in this, exact same problem as described by OP. When the previous owner took it in for service at the dealer in his city, they removed the deployable steps programming by accident. My local main dealer got me sorted and reprogrammed free of charge, which thoroughly surprised me. 2023 L460 Range Rover SE P400
Post #722335 5th Aug 2025 4:03am
