![]() | Home > Technical (L405) > Suspension fault when cornering |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
You have this topic under L405 but your profile has an L322 listed.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Sorry not updated profile
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
OP....find anything? 2014 FF Autobiography 5.0 SC
MC Member Since: 08 Oct 2019 Location: UK Posts: 4 ![]() ![]() |
Have you checked your ACE fluid level?
NoHandSignals Member Since: 28 Aug 2023 Location: MI Posts: 34 ![]() ![]() ![]() |
Hi,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
To do the job with original pipes you need to remove the rear subframe, download the Workshop Manual from the WIKI (link above right) It is a lot of work but doable for a home mechanic... I did hear rumours that the dealers charge up to £7,000 for doing it but that's probably a bit excessive...
Thanks for the vote of confidence! I ordered the factory pipes today for both front and rear. Should be here in a couple weeks.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1862 ![]() ![]() |
The pipes are too intricately shaped, and the subframe too close to the floor to cut them and rejoin without dropping the subframe... |
Thanks, Mickey. I thought that might be the case as the pipes sure do look very intricately shaped!
Good to know, cheers... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
