Home > Technical (L322) > blower motor fuse?
paulN186
blower motor fuse?
Hi all
Trying to get to the bottom of my blower not working. Changed the FSR and didn’t fix it. Changed fuse 62 for air con and didn’t fix it. I can’t find a fuse for the blower it’s self? Am I being dumb? Is there one? Next stop change the blower motor but I just spun it from the engine bay and it seems fine! 😭 any help appreciated 👌👍
Mine is a 2011 so i think different fuses from the earlier car.
Next stop is the blower motor it's self but that is a pig from what can gather so doing all the simple things first!
Cheers Paul
Post #672457 31st Aug 2023 9:39pm
DrRob
garyRR has just done a full DIY write up on blower motor change if you eventually need it.... Thumbs Up
https://www.fullfatrr.com/forum/topic67642.html
Have you tried the fuse that covers the "central console" or something like that its called? Just a curve ball idea Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #672465 1st Sep 2023 8:06am
paulN186
yeah thanks, I will be following this guide to the letter when i change it! Smile
Post #672467 1st Sep 2023 8:19am
DrRob
Good luck Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #672468 1st Sep 2023 8:20am
garyRR
The motor can eventually fail when the brushes wear out or the bearings wear so much, the additional current load fries the motor. 2015 Range Rover Autobiography 4.4 SDV8
Post #672501 1st Sep 2023 2:53pm
paulN186
thanks for the info. so do you know if there is a fuse for it? or it all done through the FSR?
Cheers Paul
Post #672504 1st Sep 2023 3:47pm
