Home > Technical (L322) > blower motor fuse? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4249 |
garyRR has just done a full DIY write up on blower motor change if you eventually need it....
1st Sep 2023 8:06am |
paulN186 Member Since: 28 Jun 2022 Location: edinburgh Posts: 39 |
yeah thanks, I will be following this guide to the letter when i change it! |
1st Sep 2023 8:19am |
Good luck Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
1st Sep 2023 8:20am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1367 |
The motor can eventually fail when the brushes wear out or the bearings wear so much, the additional current load fries the motor. 2015 Range Rover Autobiography 4.4 SDV8 |
1st Sep 2023 2:53pm |
thanks for the info. so do you know if there is a fuse for it? or it all done through the FSR?
1st Sep 2023 3:47pm |
