![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Garymcduff1 Member Since: 05 Sep 2023 Location: Wales Posts: 6 ![]() ![]() |
Thanks again for replying, is the oil drain modification the 2 returns back to the sump from the turbo? If it is mine has already been done. I've cleaned the engine several time but can't find anything whilst at stand still, it only happens when being driven so difficult to locate. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
The drain mod looks like this:
Thanks garyrr I'll check mine |
Trev Grummett Member Since: 06 Jul 2023 Location: Mackay Posts: 1 ![]() ![]() |
Hey Guys,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
I've just bought another 4 BS611 V75 from my local bearing supplier, having become aware that Viton 90 doesn't have the high temperature rating of Viton 75. Cost was $5.50 for the 4. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Nice little video
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
So Yesterday I west to a classic car rally. First blip was the keep fob not working so fixed that. Then got half way to the rally and got low oil warning. Topped up with a litre, let it rest and it didnt register. Topped up with a 2nd litre and it said under filled, fill another 1.5 litres. My heart sank.
Ok guys
I went looking for mine's very slow coolant leak today with the previously mentioned 18x2.5mm V75 o-rings on hand for the coolant fitting on the oil cooler. It didn't appear to have been leaking but I intended changing the o-ring anyway. However a test fit of the o-ring on the pipe stub revealed that the o-ring was obviously too large.
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 199 ![]() ![]() ![]() |
Image 1 looks like your EGR inlet. If you stand in front of the car looking to the rear, it will be on the right of the engine under the doughnut.
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Hi SFM
Hi Fla
Hi SFM
