Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol
Page 10 of 34 <123 ... 91011 ... 323334>
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Ahh okay so you just have one threshold for either 1=active and 2=passive, I was trying to be clever with two separate colours!
Will adjust thanks Thumbs Up FFRR SDV8 Autobiography
Post #673193 12th Sep 2023 9:39am
Gremlin500
I just have mine both set at value 1, red below one, and green above one.
For interest, other values as follows:
Oil Temp: value 90 (deg. C) red below, green above.
Soot Trigger: red if abve 55, green when below 10
Exhaust Temps: red below 500, green above 500
Distance between regens: green above 190, red below 150 (warning regens may have been missed)
Avg. time between regens: no visual warnings.
I guess there’s no right or wrong way to set it up, but I’d be interested to learn from others what they do and why? Sheep V6 Vogue - “Less is More” - less to go wrong!
Post #673196 12th Sep 2023 10:29am
James W
Super, have added some more formatting. Need to go and try it for real later (not just demo mode) and see if my Bluetooth OBD dongle works okay with it
Post #673210 12th Sep 2023 12:12pm
Kot
No --just set the top threshold to 1, the actual value will show 0 when all is OK- Regen not happening, no alarm, it will show 1 passive Regen when the exhaust temp is greater than 250C ish value no alarm. When it changes to 2 then you get visual and/or sound alarm.
See below copy of mine for visual, Ignore the red 13 screen print was done in Demo mode, the only numbers you will see here will be 0,1 or 2
Sound (again ignore the red 24 demo mode)
 2018 SE SDV8 4.4 Byron Blue
Post #673211 12th Sep 2023 12:13pm
Kot
Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #673212 12th Sep 2023 12:14pm
James W
Right just had a first go at this for real, had to pop to my folks house which is about 15 mins of suburban/rural driving, pretty continuous, min 30 max 60 mph.
First of all I was surprised to see how high the soot level was and distance since last regen. If that's in metres it means my last regen was a long drive in France on holiday a couple of weeks ago. It looks like I'm well due an active regen.
I also noted my exhaust temps never really got above 180ish constantly. So I need to get those up a lot more. I was surprised how long it took to get the oil up to temperature. It was only half way back that it happened.
I have a long drive to Leeds tomorrow so I'll keep it running and hopefully all the parameters will be met for an active regen either going or returning.
This was the screen after arriving at my folks just earlier
This was the screen after the drive back which was longer and faster
Post #673346 14th Sep 2023 12:32pm
Kot
JamesW
you can change to miles by selecting sensor properties by going down to Default units and at the bottom select None this selects Default units as miles.
Also its worth upgrading to the Pro version has you get more selections etc and its a few £'s and 1 of these is soot in grams etc maybe also reason why you see meters? 2018 SE SDV8 4.4 Byron Blue
Post #673353 14th Sep 2023 2:25pm
Gremlin500
#2 Get the “Pro” version, the free version is a dead loss. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #673354 14th Sep 2023 3:23pm
James W
Bought the Pro version - just hadn't got around to it previously. Can't find the Units field for Sensor Properties yet but it's no great issue at the moment. Looking forward to seeing what happens tomorrow on a longer motorway journey Thumbs Up
I did look to see if there was an AndroidAuto-compatible OBD app, seems there is one but it's useless. That would be really handy if Car Scanner Pro added that function Smile Thumbs Up FFRR SDV8 Autobiography
Post #673361 14th Sep 2023 4:36pm
Gremlin500
Ah! Another regeneration trainee nerd is born! Rolling with laughter
The Regen Gods (Kot & Luxmoggy) will smile on you! Bow down Bow down Bow down Very Happy Rolling with laughter V6 Vogue - “Less is More” - less to go wrong!
Post #673367 14th Sep 2023 6:41pm
TonyHammer61
England 2017 Range Rover Autobiography SDV8 Barolo Black
L405 regen problems
Hi Kot
Thanks for your reply. Do you happen to have a link to the adapter and the best iOS app to use it with please?
Tony
Post #673368 14th Sep 2023 6:43pm
Gremlin500
Gremlin500 wrote:
@MarkA,
You don't use any vehicle bluetooth profile, if I understand you correctly.
The Vgate iCar Pro BLE 4.0 connects directly to the Car Scanner Pro app in your phone via Bluetooth 4.0 (needs a newish phone)
Clear instructions are given with the Vgate unit. it's neccessary to select the correct vehicle type in the app, you can use "Demo" mode for this, and the app will remember all settings when you make the real connection.
Hope this helps.
EDIT: One more thing, be careful about which Vgate unit you buy, there are a LOT of the old ones on the net.
I think mine was £27 on Amazon IIRC.
Post #673372 14th Sep 2023 7:33pm
TonyHammer61
Amazon says that this does NOT fit a Land Rover Range Rover IV SUV 4.4 Sdv8 4X4
https://www.amazon.co.uk/Vgate-BLE-iPhone-...B071D8SYXN
Can you recommend an alternative that is compatible with my vehicle please?
Post #673373 14th Sep 2023 7:57pm
Kot
Re: L405 regen problems
TonyHammer61 wrote:
Hi Kot
Tony
I use the wifi vgate search Amazon for Vgate iCar Pro Wi-Fi OBD2 OBDII Car Auto Diagnostic Scanner Tool Check Engine Light for iOS i-Phone/iPad/Android Compatible With Adapter.
But has Gremlin says you can get the same vgate which is Bluetooth both do the job
and the iOS car scanner app is https://apps.apple.com/gb/app/car-scanner-elm-obd2/id1259933623 but get the pro version (in app purchases) 2018 SE SDV8 4.4 Byron Blue
Post #673376 14th Sep 2023 8:07pm
Kot
Re: Vgate iCar Pro BLE 4.0
I would say Amazon are wrong, any OBD2 device will fit any modern car. 2018 SE SDV8 4.4 Byron Blue
Post #673377 14th Sep 2023 8:09pm
