Home > Maintenance & Mods (L322) > Squeal from cold start only, goes away until next cold start
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
Squeal comes in 10-15 seconds during cold start at 1200RPM, then disappear once idled down, then d gone until next cold start. Seems to come from rear of engine.
L322 has 90,000 miles. Power steering pump & fluid are fine. Water pump done a couple weeks ago. Belts a year old (done with timing chain guide replacement).
Indy has cut and checked exhaust & catalytic converter on driver side as sound seems to present on that side, but nothing turned up. Wondering if coming from the transmission. Also wondering if a smoke test might show a leak that closes once the combustion heat has done it's thing to the steel...
Clip uploaded to YouTube:  2012 Supercharged L322
Post #673245 13th Sep 2023 1:47am
garyRR
If it's on that side, have you reached under and put your hand on the compressor tank to feel for any vibration? I wonder if it is something to do with the air suspension (there's valves behind the wheel arch).
The transmission is pretty central, as are the diffs. The transfer box is offset towards the left side, so less likely to be these.
I do agree though - very peculiar! 2015 Range Rover Autobiography 4.4 SDV8
Post #673252 13th Sep 2023 9:05am
TorontoDee
Worth a shot investigating, thanks. 2012 Supercharged L322
Post #673265 13th Sep 2023 11:25am
garyRR
It could also be the torque converter or transmission fluid (if you know when it was last changed). 2015 Range Rover Autobiography 4.4 SDV8
Post #673267 13th Sep 2023 12:08pm
TorontoDee
Transmission and Diffs (both) done 6 months ago. Indy has looked at the starter and TC as well.
This squeal has been a mystery for a couple years. Don't get why it's so specific to a particular timeframe only during start from cold and then disappears until the next one... 2012 Supercharged L322
Post #673271 13th Sep 2023 12:32pm
TDV8 Paul
Mine has started doing exactly the same thing today- drove me insane 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #673865 19th Sep 2023 9:02pm
TDV8 Paul
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #673866 19th Sep 2023 9:02pm
