Home > Maintenance & Mods (L322) > Squeal from cold start only, goes away until next cold start |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1343 |
If it's on that side, have you reached under and put your hand on the compressor tank to feel for any vibration? I wonder if it is something to do with the air suspension (there's valves behind the wheel arch).
13th Sep 2023 9:05am |
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 64 |
Worth a shot investigating, thanks. 2012 Supercharged L322 |
13th Sep 2023 11:25am |
It could also be the torque converter or transmission fluid (if you know when it was last changed). 2015 Range Rover Autobiography 4.4 SDV8 |
13th Sep 2023 12:08pm |
Transmission and Diffs (both) done 6 months ago. Indy has looked at the starter and TC as well.
13th Sep 2023 12:32pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 194 |
Mine has started doing exactly the same thing today- drove me insane 2007 TDV8 Vogue SE
19th Sep 2023 9:02pm |
