![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
| TonyHammer61 Member Since: 14 Sep 2023 Location: Sidcup, Kent Posts: 11
Fair enough. Amazon says that these all fit my vehicle. Which one would you choose?
| James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303
Well, well! So i set off early this morning for a long drive to Leeds, with a 70%+ trigger, and as soon as I hit the dual carriageway in about 5 mins or so, the alarm went, status went to 2, and regen percentage up to 100%. Luckily I managed to keep moving all the way to the motorway about 15 mins later where the regen finished, with the regen % dropping to the high teens then 9%.
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1888
I’ve set my Soot trigger alarm at 50%, and if everything else is “right”, i.e. engine oil at least 90C, exhausts at least 250C, tank at least 1/4 full etc etc, one hard sustained boot of the loud pedal say up the motorway slip road, will invoke the regen.
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
great you popped your cherry now it gets addictive |
| Rustybulletwound Member Since: 30 Jan 2022 Location: Yorkshire Posts: 6
Just found this thread while searching for help with oil dilution. My Mrs drives the car everyday and a lot of short journeys. Is there an easy way to monitor regeneration? She won’t have a clue with the app running. Any way of an alarm to tell her to keep driving ? Just about ready for the 5th oil and filter change in a year, I only drive it at the weekend at best
Dale
*market FFRR SDV8 Autobiography |
James, you can get the "Kot Kit" as we have, and just pop out nightly or whatever to check soot level - you don't even have to drive the car, just turn the ignition on. After a week or two, the soot will eventually get close to 50%, then it needs to go for a blast, so at 50% drive slowish to the nearest M-way allowing it to warm up properly, then hit the motorway watching for regen starting and waiting until it's finished, usually about 15-20mins of non-stop driving above about 40mph. The regen indicator will go from "0" to "2" but anyway, you will see the exhaust temp quickly start to climb from 250C to around 650C! V6 Vogue - “Less is More” - less to go wrong! |
That’s completely my plan bud, I still maintain there will be others who would value something simpler though |
Just one tip:
Yes I unplug mine too, I thought it would go to sleep but stood outside the car several hours after switch off and could still connect and read values. So I disconnected. Weirdly, if left in, it also stops my auto access height activating, you I open the door to get out. FFRR SDV8 Autobiography |
| Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 120
My “distance since last regen” also seems to be in meters, I can’t find default units. I can find units, but there’s no mention of m or “none” (I have the pro version). Could you please talk me through this? Thanks very much 2017 (67) Vogue SE Corinthian Grey |
Go into the Item Editor by tapping twice on the item you wan to edit, i.e. "Average Distance between PF Regens"
