![]() | Home > Technical (L405) > front knuckle cracking |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1778 ![]() ![]() ![]() |
Well, I am NOT reassured at all, and will continue to inspect my 2017 vehicle on a weekly basis ad infinitum. V6 Vogue - “Less is More” - less to go wrong! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
Am I right in assuming that my VIN falls outside the range XXXXXXXXXXX136906, as Gremlin not reassured but would explains why no recall. Geoff |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Exactly my point, it was mentioned earlier in the thread that the MD had used engineers blue or similar for checking for cracks. Maybe they used it so they didnt find any ![]() 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
I was talking to a LR mechanic whose gossip has generally been accurate and mentioned mine is booked for recall next week. He reckoned mine (64 plate) will get new joints because of the build date. His explanation is LR have identified suspect batches of the components as they have more than 1 supplier for some parts. On cars that have these are KNOWN to be fitted they will be replaced. On cars that they COULD be fitted to they will be inspected and if the suspect parts are fitted then they will be replaced. If they confirm that the suspect parts are not fitted then they will not be replaced as they wont fail.
If the failure happened at speed there probably wouldn't be anyone alive to report it......
"If the failure happened at speed there probably wouldn't be anyone alive to report it" - If people had died then I'm sure the fault would have been discovered during the accident investigation
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Bulletin makes no mention of galvanic corrosion, only part failure due to poor manufacturing |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 389 ![]() ![]() ![]() |
Whereas the Q&A doc states it's due to road salt, which I find ridiculous, however I guess this sounds better to the general public than we used cheap parts and sub standard QA L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
That would depend on how bad the smash was and it would be easy to say the wheel came off as a result of the crash rather than the opposite.
I thought I had read that either in this or other threads about this issue.
I dont share your confidence in JLR. It's only a few weeks ago they were denying there was a problem. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
No it doesn't - read it again. 'A crack in the front suspension knuckle may propagate in the presence of extended exposure to road salt' That does not mean it was caused by road salt. |
So, it maybe due to road salt and maybe not... They're certainly not mentioning manufacturing defects in the document, which we all know is the cause. Odd how road salt only affects certain vin ranges, maybe they started using a special salt resistant JLR coating on later versions |
Galvanic corrosion was most likely a wild guess by the herd - not a fact, at best supposition. I'd personally not put much weight in your opinion of JLR given that you're a self-confessed BMW driver: there has been no denial of an issue, manufacturers will always be 'tight lipped' on emerging concerns until they have been identified, quantified and a fix developed. BMW are well used to the process.... |
