![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303 ![]() ![]() ![]() |
Same here!! FFRR SDV8 Autobiography |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1840 ![]() ![]() ![]() |
Hmmm, looks like a different S/W version. It must be the paid-for “Pro” Version, the “free” version has known limited functionality. Try deleting/reinstalling from a reputable source.
@Kot:
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1430 ![]() ![]() |
Presume you both have pro version and Have you both selected the correct car connection profile for your car/engine? Settings/Connection profile there are 2 profiles rangeRover & landrover choose what's closest to you. The default is OBD-II/EOBD for those engines not listed. If its not in the list drop developer a line and eventually he will add it
A bit obvious I suppose, but do you now have BOTH pro & standard versions on your phone, and opened the wrong App accidentally? |
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 113 ![]() ![]() ![]() |
I’m using the pro version, 1.99.8 The best match for my car is L405 2017-2021. This is the one that shows the distance in m and has no property of miles. I’ve tried all sorts of profiles in both Land Rover and Range Rover and can’t find one with the option to set to miles between DPF regens, even using profiles that don’t suit my car (in demo mode). Which profile do you use KOT? Many thanks for trying to help us. 2017 (67) Vogue SE Corinthian Grey |
I use same L405 2017-2021 as I requested this for Facelift + L405.
Thanks again, I can get the “average between regens” to work. It’s the “distance since last regen” that shows in m and I think this would give the best indication of a missed one. I’ve emailed the developer, let’s see if he replies. 2017 (67) Vogue SE Corinthian Grey |
try changing role override to calc_distance ? otherwise contact developer and maybe ask for an addition car profile that matches your V6 2018 SE SDV8 4.4 Byron Blue |
Hi Abacus405,
Thanks Gremlin, do you have “distance since last regen”? 2017 (67) Vogue SE Corinthian Grey |
Markw Member Since: 19 Sep 2023 Location: Tyne and wear Posts: 5 ![]() ![]() ![]() |
A massive thank you to you guys that have provided all the info on this
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 101 ![]() ![]() ![]() |
Hi all,
