![]() | Home > Maintenance & Mods (L405) > Alternative to L405 gear selector |
Well you could, personally I'd just spice the pigtail you have into the existing harness so you have both connectors available should you want/need to switch back to the original rotary gear selector. |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 164 ![]() ![]() ![]() |
7 wires is a lot... if it were 4... I'd think about it.
Wrong pin size & spacing unfortunately. |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
Great work guys 👍 I admire your commitment , I am following this with great interest Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
One step closer, my brothers... one step closer to the possible end of the Maytag Delicates knob...
Yes, there is - one is a 'single' the other is part of a twisted pair with the Grey-Blue. Just expose a bit more of the harness to find which one is the twisted pair. |
I am thinking it must be Pins 2&3 on my diagram... I could not find a marking to see the official Pin number...
That would make sense - the way to confirm absolutely is to measure the DC voltage to ground, CAN lines will fluctuate 2-3V on each one. Difficult to say what the other one will be, probably a minimum of 4.5V but it will be steady. |
10/25/2023 - THIS POST HAS BEEN SUPERCEEDED - see the post on page 4 dated 10/25/2023 approx 17:25 GMT-5
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1524 ![]() ![]() ![]() |
Following this with interest, Lets hope you crack it. Jolly good luck |
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 115 ![]() ![]() ![]() |
Let's get one thing straight, JDGeorgia. What you've done with that Range Rover isn't just tinkering in the garage – it's pioneering! And I've seen a few car projects in my time. This isn't just swapping out a headlight or getting posh leather seats. No, this is ground-breaking stuff!
That looks good to me, there will be a marking somewhere on the L494 plug to indicate pin 1, but your reasoning makes sense. |
@Salsbury - flattery will get you everywhere!
I looked for a mark on the male L494 connector - if it is there, it is too small for these old eyes. @Phoenix - do you have a link to possible 'Pins' for the L405 side? I don't think it is as small as 20ga wire... 16 or 18?
I am sure this plastic cover sat down on pins embedded in a PCB. If we start mass producing pig tails (and we won't...) It might be worth it to see if that connector you had a link to would work. We would then have to find the 10 pin male L494 side. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
