![]() | Home > Technical (L405) > front knuckle cracking |
Gary M Member Since: 20 Oct 2023 Location: Liverpool Posts: 1 ![]() ![]() ![]() |
My 2015 Range Rover has had this top knuckle failure on the passenger side back in June 2021 as I pulled on to my drive way. I had to replace this my self at my expense including a new drive shaft as it pulled out and stripped the spline.
NE1 Member Since: 16 Oct 2023 Location: West Sussex Posts: 9 ![]() ![]() ![]() |
There are parts in stock, mine were ordered on Monday or Tuesday this week and being fitted today.
My safety check flagged a red warning, said 'unable to drive' when i was notified of the cracks, but i wouldn't be happy driving it knowing they were there. |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 147 ![]() ![]() ![]() |
Got mine back today. Both sides changed even though only one 'needed' it.
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 171 ![]() ![]() ![]() |
Just had a Mot and re call done on my 16 plate, not sure what happened yet.
Not a lot to tie them to with the knuckle being removed, besides, it'd get in the way and / or paint damaged. Doesn't make it right, just explaining why they'd remove the calipers. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2695 ![]() ![]() |
I understood that copper grease isn't suitable for use on aluminium with steel, or is it silver grease that isn't? |
Neither really, I don't know why they'd do that, it's not on the work instruction. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1836 ![]() ![]() |
Dissimilar metals. A non metallic grease would be advisable (ceramic based) but copper grease is much cheaper At least they greased it ![]() |
Thanks Mikey. |
Looks like this.
waveyd Member Since: 17 Oct 2023 Location: Santa Monica Posts: 9 ![]() ![]() ![]() |
I have entered a case with NHTSA stating that JLR don't have a safety recall in the USA when they do in the UK and Canada, and have given pictures. I recommend everyone that's had this issue do the same, especially is it actually failed on you.
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 155 ![]() ![]() |
Marshall would not know the truth if their lives depend upon it. Hopefully you find someone with a conscience. Or better still go to an independent who cares and get the brakes bled. Will save you a world of pain and further issues! |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1749 ![]() ![]() ![]() |
@waveyd:
