Home > Technical (L322) > TDV8 4.4 primary turbo actuator - where is it ?
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
I’m experiencing quite a bit of turbo flutter at the moment. Typically when lifting off the throttle at low revs around town…. approaching a roundabout for example. It also seems to be more prominent in warmer ambient temperatures. I have no fault codes but have a strong suspicion that there may be an issue emerging.
I’ve read on here about issues with the secondary turbo actuator sticking but the flutter occurs well below the rev range where the secondary would come into play.
My understanding is that the primary turbo is variable vane…
1.) is there an actuator on the primary?
2.) is it likely to become sticky?
3.) can it be lubed?
4.) where is it on the engine?
I have a long run down to Cornwall and back early next month so if it can be lubed I’d like to do it before then.
The WM specifically for the 4.4 on the WIKI is missing the section on the Turbo system so I robbed this schematic from another post I found whilst reading up….. would some kind sole be able to identify the relevant components on it please ?
Any advice would be appreciated. TDV8 4.4 2012
Post #676465 26th Oct 2023 12:00am
GraemeS
Australia
15 is the primary turbo.
Check the EGR throttle butterfly 7 for carbon build-up on the housing where the butterfly closes.
If your inlet isolation valve 18 is the early version that has a nut on top of the spindle then it may be sticking.
Ensure that the MAP sensor 14 is clean.
https://www.fullfatrr.com/gallery/albums/u...tions..pdf
Post #676468 26th Oct 2023 1:52am
JayGee
What leads you to think this is 'turbo flutter' esp if it's at low revs round town? When I ran petrol turbo cars this was due to slamming shut the throttle plate at high revs between gears and the turbo bypass valve not working properly. 2012 TDV8 Vogue (L322)
Post #676471 26th Oct 2023 7:31am
Ramblin Man
Thanks @GraemeS, I have the new style isolation valve. I’ll work through the other checks as soon as it stops raining here. TDV8 4.4 2012
Post #676506 26th Oct 2023 6:03pm
Ramblin Man
@JayGee what I hear is two or three short chirrups when lifting off as I describe above. This seems to match the discussion wrt turbo flutter that are on here from some years back. I’m not an expert on turbos so perhaps I’ve added 1+1 and come up with 3 ! TDV8 4.4 2012
Post #676507 26th Oct 2023 6:08pm
GraemeS
Australia
Is your PCM s/w at the latest level? Mine is April 12 build but wasn't at the level that was released before it was built and the occasional flutter that it originally had hasn't occurred since updating to the latest level.
Post #676524 26th Oct 2023 8:45pm
Chazmac
Hi I'm also having the same issue, when it does flutter it also splutters at low revs bit till I put foot down abit, my code reader is only picking up readings from 2 egr sensors, not all 4, I was thinking of gutting the dpf and mapping the egr and dpf out rather than spending a fortune on getting new sensors or a new egr fitted, would this work?
Post #676565 27th Oct 2023 9:30am
Ramblin Man
Can an Indy do that S/W update or is it an LR only procedure? TDV8 4.4 2012
Post #676581 27th Oct 2023 11:08am
DrRob
Yes. Glenrands has the full LR system. Just as if you were in a main dealer but without the carpet, expensive costs and a salesman annoying the Censored out of you Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676586 27th Oct 2023 11:23am
Ramblin Man
Thanks for the info @DrRob I managed to get it booked in next Friday. Ross & team helpful as ever ! TDV8 4.4 2012
Post #676645 27th Oct 2023 7:28pm
Ramblin Man
A big Thank-you ! to @GraemeS; your diagnosis was spot on, very impressive knowledge.
I inspected the MAP sensor today and found it to be heavily sooted. So I followed the cleaning instructions on the WIKI for it and the charge air temp sensor here:
https://www.fullfatrr.com/forum/topic48780.html
I found an air leak at the throttle body manifold joint and so have used the “PTFE tape” method to affect a running repair https://www.fullfatrr.com/forum/topic55270-30.html
until I can do the “3 O-Ring” fix documented here:
https://www.fullfatrr.com/forum/topic65345.html
So thank-you again ! Hopefully I’ll now have a trouble free run down to Cornwall and back next weekend.
The o-ring on the MAP sensor was worn and pinched in one area so I’ll replace that in due course once I’ve established the correct size.
I’m getting the S/W update done on Friday as my PCM is back level and there are several other up dates as well. So that should make a difference as too.
For Information:
I used WD40 specialist contact cleaner to clean both sensors :
This was the state of the MAP & charge air temp sensor before cleaning
And this was the internal of the throttle body:
 TDV8 4.4 2012
Post #676721 28th Oct 2023 4:55pm
DrRob
Good to hear Thumbs Up
Cleaned my MAP today too. I do it every 1000miles now Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676738 28th Oct 2023 8:48pm
Chazmac
Hi quick update, I cleaned the butterfly valve, there was abit of crap but nothing major, cleaned the sensor on the intercooler pipe with brake cleaner, it was sooted up, no more spluttering,its more responsive, thanks guys for your advice
Post #677653 10th Nov 2023 11:36am
kevinp
While you're in there it is worth removing the pipe from the EGR valve to the plenum chamber for a clean. It has about 6 holes that were completely blocked on mine. Don't know what they do but I presume they are there for a reason. Thumbs Up
Post #677655 10th Nov 2023 12:00pm
Ramblin Man
Good job! Thumbs Up
I choose to order a new MAPT sensor and MAF intercooler pipe assembly. Should be able to fit them next week and do the autumn oil and filter change at the same time.
@Kevinp: good suggestion is the EGR pipe easy to get out ?
I had to defer the S/W update for a week or two but I’ll report back on the difference when it’s done.
With Fatties you’ve just got to keep going with planned maintenance for smooth running. TDV8 4.4 2012
Post #677656 10th Nov 2023 12:18pm
