Home > General > Help needed with my IIDTool
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi everyone
Is there anyone who lives near me (Spondon, Derby) who would be willing to meet to test my IIDTool?
Patrick at Gap said it would be good to have somebody plug their tool into my car and my tool into their car.
This should help to isolate the issue I have which is that my IIDTool will not communicate with my car.
Thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #676552 27th Oct 2023 12:40am
JayGee
You could try a cheap OBDII reader to see if it's the OBD port? 2012 TDV8 Vogue (L322)
Post #676578 27th Oct 2023 10:53am
bigbo
Sorry, I should have said the port seems to be fine, my icarsoft and a cheap device work just fine.
But Patrick from GAP said their pins are smaller than most readers so checking with another iidtool would be a good idea
MG TF 2003
Post #676580 27th Oct 2023 11:01am
Baltic Blue
Mine was a bit hit and miss when I used to plug it directly into the OBD port, but has been 100% fine since I bought a short OBD extension cable off eBay.
It also gives me peace of mind that I am not wearing the socket plating on the car OBD by regularly plugging the GAP iid in and out.
Post #676596 27th Oct 2023 12:55pm
thats a good tip Mike... Thumbs Up ... - .- -.
Post #676597 27th Oct 2023 1:33pm
JayGee
Thumbs Up @Mike.
Something like this;
https://amzn.eu/d/aG3N5O3 2012 TDV8 Vogue (L322)
Post #676598 27th Oct 2023 1:54pm
Baltic Blue
That would work fine, but mine is a bit shorter.
Make sure it has got a 90’ connector on the plug end.
When you plug it in the plug holds the flap open out of the way of your foot and the excess cable easily pushes up behind the dash facia and along the tunnel so the socket is much easier to use and not in the way. Thumbs Up
Post #676600 27th Oct 2023 2:11pm
bigbo
I have been using an extension cable from the day I got the car due to the poor condition of the cars socket, but this finally gave up so I soldered a new connector in place. So its just my IIDTool giving problems.
But that has reminded me that I should check without the extension.
MG TF 2003
Post #676604 27th Oct 2023 2:35pm
bigbo
OK that was too much to hope for, it does not work in the new socket without the extension.
So still in need of help please
David
PS the car reports all sorts of errors like HDC inactive, Lost coms to gearbox etc, the sort of messages you get with a low battery. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #676605 27th Oct 2023 3:02pm
JayGee
What are the voltages with the Icarsoft so you can rule out the battery? 2012 TDV8 Vogue (L322)
Post #676620 27th Oct 2023 4:04pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
David
I had the Icarsoft LR V3 and it gave me errors like that when I plugged it in on 2 occasions !
The faults were not there until I plugged it in (just to make it clear)
I returned it to the Ebay seller and that was that.
Post #676736 28th Oct 2023 8:44pm
bigbo
Yep just the same all is good unplugged
MG TF 2003
Post #676744 28th Oct 2023 10:10pm
bigbo
Hi all, I hate bumping threads, but I am still in need of help.
I am more than happy to travel to get this sorted, so if anyone can help I would be grateful.
Thanks
MG TF 2003
Post #677505 8th Nov 2023 1:31am
Phoenix
I don't have an IID but you're welcome to plug yours into my car to see if the issue is still there - I'm working on Saturday Wink
Post #677508 8th Nov 2023 8:11am
bigbo
Many thanks, will pm you
MG TF 2003
Post #677579 9th Nov 2023 12:46am
