![]() | Home > General > Help needed with my IIDTool |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3390 ![]() ![]() ![]() |
You could try a cheap OBDII reader to see if it's the OBD port? 2012 TDV8 Vogue (L322) |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 616 ![]() ![]() ![]() |
Sorry, I should have said the port seems to be fine, my icarsoft and a cheap device work just fine.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3882 ![]() ![]() ![]() |
Mine was a bit hit and miss when I used to plug it directly into the OBD port, but has been 100% fine since I bought a short OBD extension cable off eBay.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35868 ![]() ![]() |
thats a good tip Mike... |
That would work fine, but mine is a bit shorter.
I have been using an extension cable from the day I got the car due to the poor condition of the cars socket, but this finally gave up so I soldered a new connector in place. So its just my IIDTool giving problems.
OK that was too much to hope for, it does not work in the new socket without the extension.
What are the voltages with the Icarsoft so you can rule out the battery? 2012 TDV8 Vogue (L322) |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 189 ![]() ![]() ![]() |
I had the Icarsoft LR V3 and it gave me errors like that when I plugged it in on 2 occasions ! The faults were not there until I plugged it in (just to make it clear) I returned it to the Ebay seller and that was that. |
Yep just the same all is good unplugged
Hi all, I hate bumping threads, but I am still in need of help.
I don't have an IID but you're welcome to plug yours into my car to see if the issue is still there - I'm working on Saturday |
Many thanks, will pm you
