![]() | Home > Maintenance & Mods (L405) > Alternative to L405 gear selector |
If it matches, i think it'd look very good - I wouldn't bother with the CNC cutting personally, I know it's a Range Rover! |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 164 ![]() ![]() ![]() |
Gentlemen (and Ladies?),
Some time in the shop between carving High School Football Senior gifts...
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
WOW If Tyson fury had the same commitment and attention to detail as you have my friend he would have sparked Francis Ngannou out in seconds
"WOW If Tyson fury had the same commitment and attention to detail as you have my friend he would have sparked Francis Ngannou out in seconds
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1515 ![]() ![]() ![]() |
Looking good |
Update on the electrical connector - of sorts....
Have you tried these guys?
The problem is, the connector housing isn't visible within Microcat so parts suppliers won't be able to source without a valid JLR part number. The connector has been identified as a TE connector from the OEM markings, but the OEM won't release the mating connector to end users or suppliers as they're under contract to JLR and possibly others. It may well be used as an in-line connector but the electrical libraries would have to be gone through page-by-page to identify the repair kit part number - if it exists. |
Good Googlie Mooglie! They are proud of these little ![]() I have been at a client the past 2 days, but LaShonda brought us the RRSport Console... It is piano black - not shadow walnut... but I can work with that. For my next project... Well - I need to replace the fan on my HUD Unit... But after that, I am going to fit a breathalyzer to my eBay account... Kentucky Straight Bourbon Whiskey, JDGeorgia and eBay/Amazon are not a good fit. I ended up with a dual view endoscope... I will re-crack the cupholders tomorrow and see if I can figure out how to get some pics/video of the area under the spinny knob. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
My experience with TE connectors is that if a mating connector existed then it would be referenced with the connector information. An example is the connector used for the suspension/chassis module for which no mating connector is made, except that I had a batch made using a cut-up suspension module header as a pattern because I needed the mating connectors for 2 of the 5 versions used with that header for my Llams kits. Futhermore if a special version for a specific end-user exists then it can only be purchased with written approval of that end user even though listed on the TE website, but the standard version can be purchased by any TE account customer. A local loom manufacturer was able to purchase connectors for my Jeep kits that don't have the Chrystler/Mercedes part number on them but are otherwise identical. |
The TE number is 5-963716-1
Try Mouser. |
Good call on Mouser...
