![]() | Home > Maintenance & Mods (L405) > Gearbox service ? |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 301 ![]() ![]() ![]() |
Talk to Bodsy on 7770 638023
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881 ![]() ![]() |
Alltrack 4x4 are in Malvern, and can carry out a flush |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
Find a different garage.You need AllTrack in your neck of the woods or get Bodsy on your driveway Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 159 ![]() ![]() ![]() |
Forgive my ignorance, who's Bodsy ? Does he have a real name or trading name ? |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303 ![]() ![]() ![]() |
Bodsy is a well known gearbox flush (plus more) specialist and is a sponsor over on Disco4 forum https://disco4.com/forum/member-bodsy.html
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 256 ![]() ![]() ![]() |
Cost me $475 Canadian for my independent to do it using <5L of Pentosin ATF8 (ZF8 equivalent) fluid and a ZF8 oil pan. https://www.fullfatrr.com/forum/topic64124.html
Ace ! Thanks |
Use ZF oil, it's the only one that fully meets the requirements of the OEM (others will be to minimum specification but won't have the additives only ZF use) https://www.ebay.co.uk/itm/314271555888 as an example.
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287 ![]() ![]() |
From sister owner forums DrRob kindly had a "at home" gearbox flush day. There were a few of us that graced his driveway getting Bodsy (Ian Bodsworth) to flush our gearbox. A thoroughly knowledgeable LR enthusiast and approach him without caution. No regrets whatsoever. Hunt for a L405 is on. |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 150 ![]() ![]() ![]() |
I had mine done by Marshall Land Rover in Peterborough. It cost £800, the breakdown being:
Sorry but I have had a bad experience with them. Would not trust them to change a light bulb. Ivan 2013 Vogue SE SDV8 2013 Freelander 2 SD4 HSE Luxury |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 154 ![]() ![]() ![]() |
I bought 8l of ZF8 gearbox oil and sump from a ZF distributor but only used 4.6l (oil cooler not flushed) and 2l of transfer box oil from the local JLR dealer. Cost was £480 (circa £350 if you take away the unused oil) so £1k leaves a lot for labour for what is a maximum 2hr job. |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
I used Mannol AG60 in my ZF8 on the L405 about 50k miles ago. It is still changing very smoothly and I shall be using it again soon. I also used to use Mannol AG55 in my ZF6 in my L320. Never had any issues, always super smooth changes. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
TPhipps Member Since: 24 Feb 2023 Location: Cotswolds Posts: 18 ![]() ![]() ![]() |
Not that local to you but I went to Wantage 4x4 for an ATF mega flush £395 + vat - Including filter change for my 2016 @75k miles. Just for preventative maintenance. Would Highly recommend them. |
