Home > Maintenance & Mods (L405) > Gearbox service ?
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Gearbox service ?
Hi folks
My car is at 77k so decided it would be a good idea to get the gearbox and transfer box serviced. My local garage (who I've used for years and do trust) tells me that the gearbox service inc. transfer box (at my request) was £1k !! Apparently it's dealer only supplied super special fluid.
What have been others experience on this ??
Thanks
Karl
Post #677596 9th Nov 2023 1:19pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Talk to Bodsy on 7770 638023
He will put you right.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #677598 9th Nov 2023 1:37pm
Mikey
Alltrack 4x4 are in Malvern, and can carry out a flush Thumbs Up
Post #677603 9th Nov 2023 2:16pm
DrRob
Find a different garage.You need AllTrack in your neck of the woods or get Bodsy on your driveway Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #677604 9th Nov 2023 2:31pm
Ragingrover
HTH
Ivan
Forgive my ignorance, who's Bodsy ? Does he have a real name or trading name ?
Post #677607 9th Nov 2023 3:11pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Bodsy is a well known gearbox flush (plus more) specialist and is a sponsor over on Disco4 forum https://disco4.com/forum/member-bodsy.html
FWIW I have my gearbox done on my D4 several years ago when I had it by another very similar mobile independent service via the forum at about 70k miles - and the gearbox was transformed, much smoother afterwards. FFRR SDV8 Autobiography
Post #677610 9th Nov 2023 4:15pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Cost me $475 Canadian for my independent to do it using <5L of Pentosin ATF8 (ZF8 equivalent) fluid and a ZF8 oil pan. https://www.fullfatrr.com/forum/topic64124.html
There is nothing special about the transmission as it is used in many vehicles. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #677613 9th Nov 2023 4:30pm
Ragingrover
Ace ! Thanks
Post #677616 9th Nov 2023 4:51pm
Phoenix
Use ZF oil, it's the only one that fully meets the requirements of the OEM (others will be to minimum specification but won't have the additives only ZF use) https://www.ebay.co.uk/itm/314271555888 as an example.
Opinions on 'flushes' vary, ZF have recently stated they can have value but of course, that depends upon the quality of the oil used. IMO it's no good flushing with a cheaper, lower quality oil if you have to do it more often.
Also Mannol AG60 is to LR spec - https://www.ebay.co.uk/itm/203504970860
Post #677621 9th Nov 2023 7:18pm
gettingold
From sister owner forums DrRob kindly had a "at home" gearbox flush day. There were a few of us that graced his driveway getting Bodsy (Ian Bodsworth) to flush our gearbox. A thoroughly knowledgeable LR enthusiast and approach him without caution. No regrets whatsoever. Hunt for a L405 is on.
Post #677642 10th Nov 2023 7:08am
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I had mine done by Marshall Land Rover in Peterborough. It cost £800, the breakdown being:
7 litres of oil @ £50/l = £350
Sump pan etc. £200
Labour £150
VAT £100
Figures approx from memory.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #677643 10th Nov 2023 7:34am
IGP
Sorry but I have had a bad experience with them. Would not trust them to change a light bulb.
Post #677664 10th Nov 2023 2:23pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I bought 8l of ZF8 gearbox oil and sump from a ZF distributor but only used 4.6l (oil cooler not flushed) and 2l of transfer box oil from the local JLR dealer. Cost was £480 (circa £350 if you take away the unused oil) so £1k leaves a lot for labour for what is a maximum 2hr job.
Post #677679 10th Nov 2023 6:03pm
knwatkins
I used Mannol AG60 in my ZF8 on the L405 about 50k miles ago. It is still changing very smoothly and I shall be using it again soon.
I also used to use Mannol AG55 in my ZF6 in my L320. Never had any issues, always super smooth changes. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #677689 10th Nov 2023 9:42pm
TPhipps
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
Not that local to you but I went to Wantage 4x4 for an ATF mega flush £395 + vat - Including filter change for my 2016 @75k miles. Just for preventative maintenance. Would Highly recommend them.
Post #677691 10th Nov 2023 10:01pm
