![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
No
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
OK, I have now seen it. I will ask for the "ECM DPF distance since last Regeneration" to be added to the "Range Rover, Range Rover 2017-2021". I can then start using this profile - which is more correct for my car.
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 27 ![]() ![]() |
I hope somebody can help,
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1777 ![]() ![]() ![]() |
You don’t actually HAVE to use any profile, -you can just choose “all sensors”, (assuming you know which sensors you wish to select). Once you add these to “Demo Mode” and customise the screen, your sensor selection & layout is saved for next time. |
Hmmm, I just changed mine to include “Miles since last regen” (as well as “Average distance between PF regens”)
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 110 ![]() ![]() ![]() |
Your “miles since last regen” is in metres (so you’ve done 92km or around 55 miles), I can’t get it to display miles or km, just m 2017 (67) Vogue SE Corinthian Grey |
Mine is in KM for that sensor. SDV8 AB MY 2020
@Luxmoggy:
I think it is in the software
Open the PID select tab-sensor properties and you can select miles see screenshot
That’s the average distance between regens, not distance since last regen 2017 (67) Vogue SE Corinthian Grey |
Just seen the ECM pid doesn't allow units etc but there is an Average Distance between dpf Regens in the list which works.
Hi Kot, I’m using “all sensors” as its just not there under the profile for a 2017 V6, this is what I see:
Never mind all that, I just got excited |
