Home > Maintenance & Mods (L405) > Front Brake Pads - Tools & Parts
Page 2 of 5 <12345>
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
I'd be wary of EBC pads if your running standard discs, in my experience they are excellent but at the expense of higher disc wear.
You'd be better going for Brembo's or use EBC discs as well. But then your going down the upgrade route which can turn out to be very expensive if your heavy footed.
Just an opinion. Bow down
Post #679656 6th Dec 2023 8:47pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I read about a kettle of hot water. I will try this in the morning.
I will be upgrading to EBC rotors. The only reason this needs to be done is the sticky pistons or stuck pad.
I am hoping for just stuck pad. But have ordered a rebuild kit to be sure. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #679658 6th Dec 2023 8:52pm
Gremlin500
@Luxmoggy:
It may seem obvious to some, but if you’ve not done this job before, don’t forget to turn the steering full lock to get much better access to the caliper bolts, guess which numpty didn’t…… Whistle Embarassed
When were the brake flexible hoses last replaced? It may be a good idea to do these at the same time?
They need replacing every 4-6 years or so, I’ve forgotten the exact period. V6 Vogue - “Less is More” - less to go wrong!
Post #679682 7th Dec 2023 10:30am
Kot
Its 6Y mine are on the list for March Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #679685 7th Dec 2023 11:30am
luxmoggy
I knew about the wheel turning from watching videos before starting. I will add tap-out the pins to the summer/winter tyre change - add copper grease as needed.
I am off to buy a bigger hammer while waiting for the parts.
The rubber hoses are for October 2025, I hope I don't need to take the system apart. SDV8 AB MY 2020
Post #679686 7th Dec 2023 11:36am
luxmoggy
This is like lots of little jobs they are small. Just change the brake pads. - a few hours - due to stuck pins.
Now change pads, and discs and rebuild the calliper (still to be seen) - lots of hours over a few days. This needs to be completed soon as driving to the mountains with it for Christmas. SDV8 AB MY 2020
Post #679688 7th Dec 2023 11:47am
Do not use copper slip on alloy callipers, makes the alloy the sacrificial anode and rots your callipers quicker than spraying them with salt water....!!!!
They sell alloy calliper brake grease.... Thumbs Up Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #679690 7th Dec 2023 11:56am
luxmoggy
So with the pin cut it is now out.
The 2 bolts that hold the calliper don't want to move, I have tried with an air gun and the small break bar. So I will buy a bigger bar.
For the screw for the disc is it a T45 or T50? SDV8 AB MY 2020
Post #679695 7th Dec 2023 2:49pm
Gremlin500
I did all 4 last year during my “big brakes” upgrade, it was a b*tch to bleed the brakes fully, you need to run the ABS pump with iiD tool or similar to purge the last bit of air. (To be fair, I might have done better if my collection vessel allowed air out! Embarassed)
@Luxmoggy: Plus Gas is what you need, soak the bolts the day before.
Renew the bleed nipples, and very carefully wrap only the threads in PTFE tape to stop them rotting, it creates a physical barrier between steel & aluminium. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #679696 7th Dec 2023 3:12pm
caymanblack
T50.
As Gremlin says plenty of plus gas and a long bar i had to buy a new one to remove them overfinch modified
Post #679708 7th Dec 2023 5:33pm
luxmoggy
PlusGas is not readily available in Germany. So have ordered some Liqui Moly Pro-Line Schnellrostlöser. I hope that works.
While waiting on everything, I sprayed the bolts again with WD-40.
I will try again tomorrow with the gun to loosen the bolts. The new breaker bar comes on Saturday.
This is one time it is not so good in Germany. I can't work on the car on Sunday - well it is I can't make noise. SDV8 AB MY 2020
Post #679720 7th Dec 2023 7:11pm
luxmoggy
caymanblack wrote:
T50.
How big of a bar? and how much strength/weight to get them to move the 2 bolts?
Today new axle stands arrived. They are bigger than my current ones which are are max extension to get the height needed. I will be happier trying with the bar on them. SDV8 AB MY 2020
Post #679735 7th Dec 2023 8:28pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
They torque up at 230 Newton meters so they are FT even when freshly done up. letters not necessarily in the right order
Post #679744 7th Dec 2023 8:57pm
luxmoggy
Just seen that my air wench max torque is about this so it will never undo them.
Might buy a new air wench as early Christmas present. Ingersoll Rand 2235QTiMAX. I have wanted one for a few years. It has 1760 Nm max torque. SDV8 AB MY 2020
Post #679747 7th Dec 2023 9:35pm
caymanblack
I bought this one , this with the plus gas soaked over a few days done the job.
 overfinch modified
Post #679754 7th Dec 2023 10:36pm
Page 2 of 5 <12345>
