Home > Maintenance & Mods (L405) > Front Brake Pads - Tools & Parts
Page 4 of 5 <12345>
Gremlin500
Don’t forget the rears 😉
Not quite so “shouty” with the wheels on:
If a jobs worth doing, etc. Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #679997 10th Dec 2023 5:56pm
Phoenix
Post #679998 10th Dec 2023 6:05pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Sorry, I'm not painting them this time as I am on a time limit, if I did I would probably go for black...
I will post pictures again tomorrow.
For those who replaced the wear sensor. Do I need to remove the whole inner cover or can I remove the one fastener (just by the wire and holding the 2 panels) and do the job? If I have to remove the whole cover how many fasteners are there? It looks like 6 in the workshop manual. But I can also see a screw. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #680004 10th Dec 2023 8:11pm
luxmoggy
List of Tasks left to do. I need to finish by Tuesday night. So I am happy i got some done today. I am hoping the local LR garage has the bolts and screws in stock.
Driver's Side
1. Fit wear sensor (front wheel liner)
2. Replace and torque the disc screw
3. Torque the calliper bolts
4. Fit pads, pins, spring and bolts
5. Fit wheels and torque bolts
Passager Side
1. Remove the disc screw (I hope the impact screwdriver works) - was told drilling could be the solution
2. Remove calliper
3. Remove disc
4. Clean the matting surface
5. Temp refit calliper to clean
6, Fit the disc
Then follow steps 2-5 from above. SDV8 AB MY 2020
Post #680005 10th Dec 2023 8:23pm
Phoenix
Post #680007 10th Dec 2023 8:51pm
caymanblack
Gremlin i dont thinkyou should paint the whole disc. Rolling with laughter overfinch modified
Post #680008 10th Dec 2023 8:57pm
Phoenix
Post #680010 10th Dec 2023 9:23pm
Gremlin500
I didn’t paint anything, it all came like that!
My lovely double garage (see other threads) is now a tart’s boudoire “gym” with soft rubber floor (ooh-err missus), treadmill, bench etc., so I dare not spray anything in there except tans. Laughing
Sorry, slightly OT there, Embarassed V6 Vogue - “Less is More” - less to go wrong!
Post #680015 10th Dec 2023 9:48pm
luxmoggy
So I am off to the garage to buy new screws and bolts.
The disc screw didn’t move. So I had to drill in out. All of the treads are still intact.
Was fitting the wear sensor from EBC they have the wire routing rubbers in another place. Do I will take the old one to the garage to see what they have.
But now it should be simply putting it all back together. SDV8 AB MY 2020
Post #680050 11th Dec 2023 12:58pm
luxmoggy
Disc are on. Just need to do the pads in the morning.
The disc screw which I drilled and thought the threads were are ok. They aren’t. I have borrowed a tap but it isn’t going working. Read that screw is only for putting it all together. So will skip for the moment and get that sorted later. SDV8 AB MY 2020
Post #680066 11th Dec 2023 7:13pm
luxmoggy
All finished. First test drive done - just around the block.
All looking good…
I will check I can move everything in the spring when I go to my summer wheels. SDV8 AB MY 2020
Post #680111 12th Dec 2023 10:48am
JCW
Without wanting to appear pedantic, the retaining spring is not quite located into the two retaining pins correctly, may not make any difference in practice but probably worth shifting it across so it locates into the rebated sections 👍 Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #680116 12th Dec 2023 11:14am
luxmoggy
the replacement pins are shorter than the ones I took out. I can't get the pins in further. I will check with the parts at the local LR garage. SDV8 AB MY 2020
Post #680120 12th Dec 2023 11:43am
luxmoggy
So I need the kit LR113962 and not LR016683.
Which has the longer pins?
So I will now see if I can get it. SDV8 AB MY 2020
Post #680122 12th Dec 2023 12:07pm
caymanblack
I,m feeling nervous:? As JCW says,make sure the parts are correct Lux.
Groved Discs look good. overfinch modified
Post #680125 12th Dec 2023 12:23pm
Page 4 of 5 <12345>
