![]() | Home > Maintenance & Mods (L405) > Front Brake Pads - Tools & Parts |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
Sorry, I'm not painting them this time as I am on a time limit, if I did I would probably go for black...
List of Tasks left to do. I need to finish by Tuesday night. So I am happy i got some done today. I am hoping the local LR garage has the bolts and screws in stock.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
Gremlin i dont thinkyou should paint the whole disc. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1777 ![]() ![]() ![]() |
I didn’t paint anything, it all came like that!
So I am off to the garage to buy new screws and bolts.
Disc are on. Just need to do the pads in the morning.
All finished. First test drive done - just around the block.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 925 ![]() ![]() |
Without wanting to appear pedantic, the retaining spring is not quite located into the two retaining pins correctly, may not make any difference in practice but probably worth shifting it across so it locates into the rebated sections 👍 Jonathan
the replacement pins are shorter than the ones I took out. I can't get the pins in further. I will check with the parts at the local LR garage. SDV8 AB MY 2020
So I need the kit LR113962 and not LR016683.
I,m feeling nervous:? As JCW says,make sure the parts are correct Lux.
