![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 111 ![]() ![]() ![]() |
It’s only the diesel models that are affected 2017 (67) Vogue SE Corinthian Grey |
W00lyCh3f Member Since: 18 Dec 2023 Location: Chester Posts: 15 ![]() ![]() |
Apologies, I should have made myself clearer, completely understand it's only the diesels affected by the DPF regens. I'm just in a position of looking at both engine options. @fisha thanks for the info. Sadly I'm not really in a position to do the servicing myself, or at least I have never done something like that before. I've watched a few videos, looks to be, I'd need ramps etc to get under the vehicle to complete the work. Although, you are right, I could simply pay an independent to complete the service if more regular. Albeit it's time off the road. My mileage is a real mix, of either super local (golf club / parents / shopping), but I also do at least 2 journeys a month of approx 150 -200 miles each way, most of which is motorway cruising. Hopefully that will give it the optimum time to complete regens etc. |
TJNZ Member Since: 17 Apr 2022 Location: Auckland Posts: 19 ![]() ![]() ![]() |
I honestly dont think its a major in terms of an oil change. After reading online here and a few you tube videos (Raymies Garage) I am thinking its relatively simple not requiring any ramps etc. Just a extractor pump, the oil and filter and a socket for the oil filter. I have never changed oil before but am prepared to give it a go and have just got my service kit from lrparts.net (unfortunatley shipping is expensive to NZ) and bought some C1 oil locally here in NZ. I am actually looking forward to it.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1409 ![]() ![]() |
In that case the 5 litre petrol is a no brainer 2018 SE SDV8 4.4 Byron Blue |
I tend to agree given the style of driving you are doing and if there are no fuel cost considerations either from a consumption perspective or simply petrol vs diesel cost. For my use case where I was doing 1200km round trips once a month the diesel made more sense. I had the my previous RRS SCV8 remapped with the pulley upgrade and it really was intoxicating but I found just the thought of the cost as I pressed the accelarator dulled my enjoyment. All the best with your search. 2017 L405 AB SDV8
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
If fuel cost isn’t an issue, then petrol everyday of the week for me… but it is an factor for me , so diesel wins it. But it’s not by much as time has gone on.
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 197 ![]() ![]() ![]() |
Very interesting thread with bags of info. I just got my 405 v6 set up using WiFi but when it made the connection a lot of the sensors disappeared including the all important trigger point. I ordered the ELM WiFi by mistake maybe I would be better with Bluetooth.
RE my previous post, I suppose the DPF differential pressure can be the trigger point but how will I know when a regen is in Pro? There is a sensor for catalyst temperature but I can't remember if the cat is upstream or downstream of the DPF . Any ideas and advice most welcome
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1792 ![]() ![]() ![]() |
Hi Pete,
@Pete:
I use wifi, with no issues, you have to chose the network VLink are you using the correct profile? 2018 SE SDV8 4.4 Byron Blue |
Thanks for the replies. I got the wifi connection working and all seems fine, just need an excuse for nice long run to try it out now.
Go see Gremlin he will sort it for you, same V6 as well, so you should have the same profile as he has and copy same pid items on your screen. 2018 SE SDV8 4.4 Byron Blue |
@Pete:
