Home > Technical (L322) > Howling 4.2 S/C!
Anvil
Howling 4.2 S/C!
Hi guys,
(Thankfully) a little while since I’ve posted, but a quick question please!
My lovely ‘06 has been as good as gold and so far I’ve only had to fix wear and tear items in the last four years. Yesterday she’s started to make a bit of a howling/whining noise that I can only describe as sounding like a service bus! I popped the lid, and had a listen as it rises and falls with engine speed. There’s a slight whiff of electrical and the sound seems to be coming from the alternator. I’m a short git, so can’t get close enough to tell for sure. All electrics are (so far) running fine, but is my howler a sign that the alternator is on the way out and I should replace it asap? Is that a normal indicator of an impending failure?
I’ve only just replaced the rear lower arms and rose joints so does anyone have any ideas how much I’m likely to be hammered for if it does turn out to be the alternator? Cheers in advance and wishing you all a great new year!
Si. FFRR 4.2SC/KTM 990SMT Current and cherished.
Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids)
Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R
TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.)
Honda Integra Type R DC2 Possibly the best drivers car. Ever.
Mitshibishi FTO GPX MIVEC.
Honda CRX Vtec Mk2 -NO, Not the del sol!!!
Volkswagen Scirocco GT
Mini 1275GT
MG Midget (Heavily modified)
I'm going to stop now.....
Post #682170 8th Jan 2024 6:51pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Mine started to whine although not as loud as yours. I bought a cheap mechanic’s stethoscope, put it on the alternator and bobs your uncle!
Fitted new alternator and all is well.
Mine is an 06 S/C too 👍
Post #682175 8th Jan 2024 7:13pm
Anvil
Thanks for the speedy reply Philip, was it an expensive job please?
Mini 1275GT
Post #682177 8th Jan 2024 7:19pm
Weegie
Just had same symptoms and new alternator was needed. Cost of alternator plus book which is 3.7 hours. Unless you do it yourself .
I knew what it was but it packed in before I got round to it. A new LR one was quoted at over £800 and a LR re-con was over £500.
I went with a Lucas aftermarket at £300 odd as it was getting to the stage of repairs taking it over the car’s value.
Done by my indie at total of £730 😢 John
GAP iiD BT-Sold
Post #682179 8th Jan 2024 7:23pm
philip1972
I replaced it myself, I think the alternator was about 250 euros (I live in France). But I did buy a denso which was the original brand. Cheaper ones were less.
Post #682182 8th Jan 2024 7:50pm
philip1972
Just checked and my Denso was exactly 254.81 euro
Post #682191 8th Jan 2024 9:12pm
Anvil
Brill (apart from the cost….) cheers lads! Is it a job from the top or underneath? FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #682193 8th Jan 2024 9:54pm
dhallworth
It can be done from the top.
You’ll need to remove the fan shroud and viscous fan (you’ll need a viscous fan spanner), once that’s off, remove the belt, and then by feel you can remove the wires and bolts from the alternator and pull it out of the front.
I changed mine a couple of years ago as it was putting out a max voltage of 13.5v.
The original one on the car is a Denso.
https://www.ebay.co.uk/itm/275864264076?mk...media=COPY
Post #682196 8th Jan 2024 10:22pm
philip1972
I got away with not removing my fan and shroud, although access was swear inducing! I did have to unbolt and move the expansion tank and bracket though.
Post #682204 8th Jan 2024 10:54pm
Anvil
I love this place! Thank you all so much!
Brill help!
Mini 1275GT
Post #682205 8th Jan 2024 11:03pm
